Interesting!
Is the point to stop the bolt from rattling inside the collar?
Picture?
Picture?
Sorry my internet explorer didnt show the picture in the beginning but now it`s there
yox185
Doesn't this keep the roller from rolling?
Nine2Nine
yox185 said:Doesn't this keep the roller from rolling?
Bolt is too long and this takes up the space, My O-rings went missing as well.
yox185
I see it now.
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
you can also use a thicker nylon washer alone both sides
ViperTurboPete
- Mar 25, 2005
- Sudbury, Ontario
- 2015 Viper XTX LE MPI Turbo
2022 Expedition Extreme 850
WoW! I can't wait to try it! My clutch rattle is so loud that I am embarrassed to have the sled idling with anyone standing around.
I thought my sled was the only one rattling. I was even too embarrassed to make a post on it.
trailbreaker
Old Thumper ---i just used the nylon washers no o-rings. I also did this with my Phazer too and no problems .
09nytro
The noise isn't that bad I can live with it
canoehead
- Jan 14, 2011
- NE, Alberta
- 2014 XF9000, 2016 Viper XTX
X209nytro said:The noise isn't that bad I can live with it
yamadoo
- Jun 3, 2003
10 Vector LTX Blue 9kmiles
11 Venture GT 4k miles
86 SnoScoot(2) for grand kids
I know the noise isn't "bad" but I am still going to do the two nylon washer trick. I will just like it more. These are the worlds greatest motors in sleds and like it when it sounds that way.
Yamadoo
Yamadoo
woolyviper
- Mar 24, 2006
- hibbing,mn
- 2009 Yamaha Phazer RTX
i think yamaha's original fix for the vectors was a plastic washer in the same position - same thing.
Mountaintech
If you think the noise isn't that bad, listen to what the engine sounds like without the primary clutch. Take off the clutch and try it.
canoehead
- Jan 14, 2011
- NE, Alberta
Ya but it doesn't go very fast, does it?Roest said:If you think the noise isn't that bad, listen to what the engine sounds like without the primary clutch. Take off the clutch and try it.
lol
Hmm I wonder why the bolt is too long?
I cant understand why it is like that if it doesnt serve a purpose??
If you add o-rings or washers to remove the "slack" why couldnt you just cut the collar and or bolt so that it becomes tight?
I figure it has something to do with reducing wear on the bushing inside the roller?
Or do they just want to make sure that you dont create "tension" in the clutch to avoid exploding or something?
hmm
hmm
- 125K
