Clutch Rattle Gone...................
mjaremko
Suspended
Spokane,WA.
Some one posted this fix about six months ago, just wanted to say thank you to whoever it was and post a photo for the rest that havent done it yet. It is very simple and it works.
The fix is the small O ring on the left side of the roller bolt, click on photo to enlarge.
mj
So for us clutch newbies is it really as easy as loosening the bolt installing the O ring and re-tightening?
If so what size O ring and what torque on re tighten?
Yamadoo
Yes,
Its as easy as removing the nut, placing a small "O" ring that I bought at Home Depot on the bolt and re-installing the nut. My torque wrench doesnt go that small so no idea on the torque.
mj
I tried it and it eliminates the rattle. However, I have been unable to keep the o-rings inplace, they were gone after the first ride. Must be the harmonics of 3 cylinder engine generate more rattle then then Apex models. A small washer washer would be ideal.
X2.....
Maybe I got better O rings because mine have been in around 300 miles and look fine. I used small ones, barely large enouph inside diameter to fit over the bolt, then crushed it down hard with the bolt.
mj
I had mine running tonight and all the covers were off and I said to my buddy, OMG is the ckutch loud!! Thanks, I'll add those tomorrow!
I also tried it , but can't keep the o rings in they came out on first ride but it did work for a little bit
I posted it...it was my idea....you can get a thin nylon washer to act as a keeper for the O ring...
I used the thin nylon washers #10's from lowes and put them on both sides . I have 700 miles on them and no problems and they are still there.
Nylon washers AND O-Rings? Or just the washers?
