Crossfire12
- Feb 13, 2017
- New York Adirondacks
- Sacandaga reservoir
2350 shouldn’t you have changed belt around 1800 running a tune belts wears a lot ,just curious. How many miles do you expect on a tuned sled?Just like F1 tires.
My OEM belt shredded at 2350 miles. Was still a belt but outer material shredded off. I hoped off and grabbed the clutches as soon as I was stopped and had the panel off and could keep my hands on the clutches. Didn't even pull out my temp gun.
Really all we would need is the LED indicator in a really small mount. 3 bills is kinda steep.
actionjack
- Apr 9, 2005
- Westminster, Maryland
- www.inspectorjack.com
- 2017 SideWinder LTX-LE
I guess so. Or maybe 2300.2350 shouldn’t you have changed belt around 1800 running a tune belts wears a lot ,just curious. How many miles do you expect on a tuned sled?
Actually just the day before I roasted the 850 Skidoo in our group on Parlin Lake after we swapped for a while and he thought his 850 would hang. Not.
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
IMO 1500-2000 miles or when the cord starts pulling. Check the belt once you get Into the 1500 area. Check it often but really start watching it more with more miles2350 shouldn’t you have changed belt around 1800 running a tune belts wears a lot ,just curious. How many miles do you expect on a tuned sled?
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
This is way way too hot!! Only one hard pass in the deep snow too!
218 belt temp. And I also corded the belt on this one run.
173 secondary temp.
View attachment 152084Agree the temps you had a few days ago,as mentioned 145 belt,pri 120,sec 90 those are almost perfect,but these new temps very bad,and I to have had temps where you were today mike.
183 primary temp.
Last time out If I remember correctly after 3 back to back to back pulls,
I had 145 belt temp.
Primary temp of 120.
Secondary temp of 90.
I'd consider those really cool and happy.
Turboflash
- Mar 18, 2019
- Southern MN
Thanks. The gage was originally designed for ATV/UTV application. The cable length from gage to sensor needs to much longer for those vehicles compared to our sleds. I had to coil up excess cable inside my hood to make the connection come out where the stock hood connector is. So that's good if they made one for sleds with a shorter cable.Temp Gauge 3.0 select snowmobile size.
Razorback Technology Infrared Belt Temp Gauge - 3.0 Edition (Snowmobile) https://www.amazon.com/dp/B01M21B80Y/ref=cm_sw_r_cp_api_i_IgKgEbBFBRHR6
actionjack
- Apr 9, 2005
Yeah. I'd be super interested if they made it cheaper with just the LED set similar to the settings you have yours. Don't feel compelled at this point since I haven't had belt problems.Thanks. The gage was originally designed for ATV/UTV application. The cable length from gage to sensor needs to much longer for those vehicles compared to our sleds. I had to coil up excess cable inside my hood to make the connection come out where the stock hood connector is. So that's good if they made one for sleds with a shorter cable.
Only 5 left at Amazon earlier today BTW.
- 17K
