turbo800
- Jul 24, 2014
- UT
- '15 Viper MTX 162 LE w/ MPI 180 turbo
Cranked out a few shims on the lathe today for some testing...
Few different sizes to mix and match:
2- 1mm
2- 2mm
2- 3mm
1- 4mm
2- 1mm
2- 2mm
2- 3mm
1- 4mm
Still waiting for somebody to fire one off and check the engagement speed. Last I heard the MTX was engaging at around 6k, hope that changed.
It says 3900 rpm engagement. Still has that pink spring though.
Here are all the specs for mtx
stingray719
.View attachment 99539
Interesting, Ulmer said (unless I read it wrong) the MTX was coming with a Blue-Brown-Blue spring. Makes more sense with the GGG and 14.5 rollers, with the middle "green" showing a lower engagement than the "white" middle identifier. The green-green-green shown in your pic is very similar to the green-white-green we put in our cheap kit. I may have to try a GGG with a shim just for fun. This should be interesting!
BBB is 50 - 116 at 98.4mm length
GGG is 40 - 131 at 87.9mm length
GWG is 45 - 136 at 89.8 length
How do our rollers compare? Can't believe they are running that secondary spring. Do they not ever hold it tight? You know just because casting numbers are same doesn't mean they don't have machining differences. Only way I would be sure would be to measure. Heck you might not even need the shim in your clutch kit anymore. I believe the pocket is machined. At factory they could just machine less or more.
stingray719
Parts fiche shows 8FG-17624-20 in your and my XTX also. Chart below (that I stole from another thread on TY) says ours is 15.6mm. Larger rollers quicker backshift and less belt pressure.
Thanks. Sure hope the river here is safe this year. Awesome place for testing all these things. Last year it froze nice and then broke up for a week before freezing again leaving big chunks under snow. Was very dangerous if you got off the 1 sled wide path. It's a five minute ride on sled from my house. Well broken in and can't wait to keep it pinned for miles if needed. For me my goal is to get all the performance I have now with a 8jp size belt so I can avoid any machining of the clutches. If my old srx could easily hit 110mph there which it did and more many times with no clutch machining this sled ought to be able to hit 100 or more and have clutches that look as clean as with 8dn. If not can always go back to 8dn.
stingray719
8DN does not require any clutch machining to work, just 3 washers to change belt deflection. I have an experiment I am doing with Terry to maybe find a cheap and easy solution to the spring bind issue....more to follow after testing.
- Apr 14, 2003
- Hessel, Michigan
I am hoping the river is better this year also Cannondale. Plus, I hope the trail is superb by me like it was last year as it is awesome to have my test track 200 feet away from my driveway. 1 nice thing is the groomer will make a turn around for me so I have a fresh track now
Timer will be setup on certain days if anyone wants to do testing. (The trail is on my friends property so we can park the sleds, sit and bs....but just need to be courteous to the other trail riders). If needed, my house is right there also
Can't wait Nos.
Got the new secondary spring from Ulmer. Hope that takes care of binding.
Kerrdog569
- Sep 11, 2014
- East jordan,michigan
- 2017 Yamaha sidewinder xtx se
I wish I lived closerI am hoping the river is better this year also Cannondale. Plus, I hope the trail is superb by me like it was last year as it is awesome to have my test track 200 feet away from my driveway. 1 nice thing is the groomer will make a turn around for me so I have a fresh track nowTimer will be setup on certain days if anyone wants to do testing. (The trail is on my friends property so we can park the sleds, sit and bs....but just need to be courteous to the other trail riders). If needed, my house is right there also
Kerrdog569
- Sep 11, 2014
I couldn't get the belt deflection I wanted even with 3 washers,the clutch sheaves were almost touching and the belt was still sitting down or almost even with the top of the secondary,could be my belts on the long side of spec too but I sent my clutch for machining anyways to fix both issues,coil bind and belt deflection8DN does not require any clutch machining to work, just 3 washers to change belt deflection. I have an experiment I am doing with Terry to maybe find a cheap and easy solution to the spring bind issue....more to follow after testing.
stingray719
You added 3 more everyday variety washers to the original 3 washers and still couldn't get enough? Very odd.
RTX
- Mar 31, 2005
- massachusetts / maine
- 2014 viper rtx
2006 apex rtx
Dont think you can add much more than 3 washers under that bolt.
I think 3-4 washers has the clutch sheaves hit each other.
If i remember right, to get my belt riding at the correct height in the secondary i had to pull out all 3 bolts.
Kerrdog569
- Sep 11, 2014
I got the same washers from my dealer and had three stacked on each bolt so the sheaves were almost touching then I started the sled and ran it then checked the deflection plus how high the belt was riding and it was flush with the top of the secondary and seemed too loose,now on my other brands of sleds I've always ran my belt deflection as tight as possible without the sled wanting to creep ahead,if I grabbed the secondary I could spin the belt around the primary really easy,so it's too loose IMOYou added 3 more everyday variety washers to the original 3 washers and still couldn't get enough? Very odd.
