I wanted to start a new thread about clutching but lets not let it go to the Dog Pile this time. Feel free to talk about your sleds kits....just lets not make this a sales ploy, this is a information site 1st...K
I sure could use some good old OEM free clutching advice!!!
Tom
Tom
SledFreak
- Feb 7, 2005
- Ontario. Canada
Uhmmm, wonder who you are talking about?MrSled said:I sure could use some good old OEM free clutching advice!!!
Tom
Sled Dog
When climbing with my stock 04 Rx-1 moutain I was revving 10200 to 10400 with a track speed of 80 something kph it didnt climb that bad actually. I also like to use this sled for trails. I do more trail riding than hill climbing for sure but where I live it is nice to be able to do both with one machine. My question is what would the clutch gurus suggest for me. Leave her be or is there something I could do that would make me like this sled even more. I am 250 lb rider and I dont ride agressively on the trails.
87gtNOS
- Nov 30, 2005
- Toronto
- 12 Apex XTX MCX powered
Sled Dog said:When climbing with my stock 04 Rx-1 moutain I was revving 10200 to 10400 with a track speed of 80 something kph it didnt climb that bad actually. I also like to use this sled for trails. I do more trail riding than hill climbing for sure but where I live it is nice to be able to do both with one machine. My question is what would the clutch gurus suggest for me. Leave her be or is there something I could do that would make me like this sled even more. I am 250 lb rider and I dont ride agressively on the trails.
Hey, I don't know much about Yammy clutching yet...but I do know clutching!!
Does your sled lack performance on the trail? You say it's actually good in the hills. Can you tell us what you want it to do on the trail. Maybe someone can suggest a helix change or something for you!
AIRWOLF
Guest
MrSled said:I wanted to start a new thread about clutching but lets not let it go to the Dog Pile this time. Feel free to talk about your sleds kits....just lets not make this a sales ploy, this is a information site 1st...K
Tom
A
Anonymous
All I'm going to say at this time is this -
We are the exclusive Canadian Distributor for ProLine Performance. John will be directing all orders from Canada through our business. We will be doing testing ourselves for the FUN and benifit of testing in general and to share info with fellow sled enthusiasts.... Tom has accepted financial support from John at ProLine Performance and has confirmed with me it's permitted to PM or EMAIL us through the site here if you have any questions. You will be served properly and professionally
Everyone have a Great Week!
Spenc
PS: Thanks for being "KooL" Tom
PSS: Pic of testing pad. Will hopefully be using triple piped Viper for comparison sled ( midrange comparison - stock to ProLine kit supplied)
PSSs: Sorry... No Film Crews as of yet ( but we're work'n on it )
peace out
Spenc
peace out
Sled Dog
When going really slow I find the clutch engagement to high. What I mean by this is where I ride in the Ducks there are some real tight turns and the trail narrows where you have to go really slow. I find I have to kick it in then back off kick it in & then back off but only when I have to go really slow. As for top end on the trails and lakes I have enough top end for me there already.
87gtNOS
- Nov 30, 2005
- Toronto
Sled Dog said:When going really slow I find the clutch engagement to high. What I mean by this is where I ride in the Ducks there are some real tight turns and the trail narrows where you have to go really slow. I find I have to kick it in then back off kick it in & then back off but only when I have to go really slow. As for top end on the trails and lakes I have enough top end for me there already.
Geez, if it where as simple as Cat clutching..I would add some weight to the primary and maybe run a dual angle helix with a smaller finish angle than you have now. This will bring down your engagement some and the helix will help keep you peek rpms up.
It can also be achieved with a different primary spring..but again, there are so many damn Yammy springs, I am not sure where to start!! Softer start and a slightly stiffer finish and similar rate.
APEXER1
-------------sled dog----------
Have you tried the bigger wheels yet. Mine use to do the same thing until i change them. Plus i raised the idel...
Buster696
Sled Dog,
Looks like you have a mountain sled, and I believe they came with the bigger rollers in the stock clutch (please let us know...). If you run a smaller roller, it will lower your engagement (It will also squeeze your belt better…). But, it will also raise your top end RPM a little maybe 100/200rpm). In order to fix that you either have to run more tip weight (I suggest this), or pull back on the helix angle (51/43 to 51/47 for example) with no changes to the primary weights...
Hope this helps...
--Buster696--
PS. Tom, how's this for a civilized clutching post... (he, he...)
Hope this helps...
--Buster696--
byoffcr
Did a little testing . Put my stock clutching back on my attaks.. Milage about same. One pull 500 more rpm than the other. Switch clutches same sled 500 higher rpm.. Can one motor be that much stronger than the other?
87gtNOS
- Nov 30, 2005
- Toronto
byoffcr said:Did a little testing . Put my stock clutching back on my attaks.. Milage about same. One pull 500 more rpm than the other. Switch clutches same sled 500 higher rpm.. Can one motor be that much stronger than the other?
This could be why the weights are adjustable?
dirkdiggler
Suspended
I would say yes it could. Is the Milage the same on both?
byoffcr
With in 1/10 gal on fill up.
