stuckless316
Out riding the weekend and about 15-20 min into the ride my sled dropped the rpm and picked up again. On low speed (around 40kmh) was fine but as soon as I tried to open it up again it would drop rpm, with the same codes coming up. Sometimes it would even shut down It got so bad by the time I was trying to load it on the trailer it would shut down altogether while trying to load it without any codes appearing.
I know the codes are ignition coils for cylinders 1-3 respectively.
I have it in the dealer now and all they thought it was, was the throttle cable not adjusted properly, they tried that and took it out for a run and the problem occurred again.
I was wondering if anyone else has had this problem and what they did to fix it?
stuckless316
Well got the sled back today from the dealer, and it was a wire chaffed behind the clutch that was causing all the grief! Took it for a 50km ride today and the problem is gone, no more codes and no more dropping rpm when i try to open it up!!!!
