Rtbo
- Feb 18, 2016
- N Syracuse
- 23 SRX
- N Syracuse
I ordered a complete driveshaft online a few days ago and just received a email that it is on nationwide back order. Does anyone know where I can get one
FrozenTows4
- Nov 6, 2014
- Brainerd Minnesota
- 2014 XF7000 Sold
2017 ZR6000RS
2018 ZR6000 El Tigre
- YOUTUBE
- FrozenTows1
Shows in stock.
https://www.countrycat.com/arctic-cat-part-2602-740-shaft-drive-hex-45mm-bottom-brake
May want to call to be sure.
Edit: My bad. You were looking for the complete assembly.
The complete assembly says "special order item" so probably the same deal here.
https://www.countrycat.com/arctic-cat-part-0728-236-drive-track-9t-2-86p-exv-assy-8m
But it Does say, ships 3-4 days? Worth the call.
RAMSOMAIR
I ordered the complete assembly from Country Cat 4 weeks ago and had it in 4 days. Guess its popular lol.
Mountaintech
Why the replacements? Are driveshafts failing?
IH8CROWS
Really? Where ya been.Why the replacements? Are driveshafts failing?
You have some reading to do. LOL
Mountaintech
In the Nytro forums for the last 11 years.
eightpilot
- Mar 17, 2009
- Mosinee WI
- 2021 Thundercat
- Mosinee WI
My dealer had one for me the next day.
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
Not really failing but design flaw, which allows the bearing ( pressed in the brake caliper casting) to just slide on the driveshaft with a too loose fit, thus the bearing spins on shaft ruining shaft!
Not an easy one to find unless you are a DIY maintenance type, otherwise it may take some mileage to show itself and at that point probably damage on other end (chaincase) also.
NYTurbo
hurricane performance is trying to keep the shafts in stock.
Turboflash
- Mar 18, 2019
- Southern MN
3 weeks ago, according to my dealer, there were over 700 on back order at factory.
Rtbo
- Feb 18, 2016
- N Syracuse
- 23 SRX
- N Syracuse
I found one through arctic cat, I called first and the lady said they have it in the arctic cat warehouse. Hope it’s there. If not has anybody had luck with the aftermarket driveshafts? I remember a while back someone put up a bad review of black diamond extreme I think it broke with only a few miles.
NYTurbo
The BDX steel shafts are fine. Weve put over 400 hp on them and launched at 10 pounds of boost .
Rtbo
- Feb 18, 2016
- N Syracuse
- 23 SRX
- N Syracuse
Are the tolerances the same as stock or tighter
Mountaintech
Thanks for the clarification.
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
No,some are spinning on the shaft,poor fit of bearing to shaft.Why the replacements? Are driveshafts failing?
- 6K
