Scott Jamieson
- Jun 10, 2019
- 2017 Yamaha Sidewinder LTX-LE
My TD kid arrived today with the Dalton 70G, instructing a 7.74G set up. Using the 3/4" and then the 1". So....does that mean the 3/4" is in the tip/toe and the 1" is in the heel ? (why the instructions don't say I don't know) Please help me, I got one shot at this.
Scott Jamieson
- Jun 10, 2019
Correction Turbo Dynamics burn. Dalton clutch kit. 70G instructing that 7.4G be added. Using 3/4" and 1". Which goes where in Tip or Heel
Fleecer
- Jun 13, 2014
- 2019 SRX
Put 3/4 first or in tip, then the 1 inch.
DTR 82-27
- Dec 22, 2006
- Drumbo, ON
- 2018 SIDEWINDER S-TX DX 137
By Dalton 70G do you mean QAY70? If so, here is a copy of the instructions that I have and they can also be downloaded from the Dalton website. I’m surprised this page wasn’t included in your kit. About half way down the page in bold and underlined text it says to never put the 1” weight in first. it also says to use blue Loctite on the weights.
Mike at TD told me to put the first weight in until it bottoms out then loosen it about a 1/4 turn. Then put the second weight in.
Fleecer
- Jun 13, 2014
- 2019 SRX
If putting 1 inch slug in first, you must back it out 1/2 turn from buttomed out as it may get stuck. All other sizes can be screwed all the way tight to the tip and/or against each other without issue.
Scott Jamieson
- Jun 10, 2019
OK. Thank you both for your help. I do have the yellow instructions. It wasn't making sense to me, however...You helped me realize that both weights are inserted in the heel ands screwed to bottom out on the tip and against each other. My confusion was based on my experience with heel clickers that have weights in 2 or 3 different locations. Thank you.
Winder_506
- Dec 21, 2012
- New Brunswick
- 2005 rx warrior
2013 apex xtx with woodys power up kit clutch work and mbrp pipe
If your going to run a XS belt you will need those weights empty. I bought the DTya1 which on my scale were 74.6 gram. I ground 4.6 gram off each one to get rpm back up to 8850 on max 17 tune with XS belt. Just food for thought as Yamaha belts will go about 500 miles if your tuned.
actionjack
- Apr 9, 2005
- Westminster, Maryland
- www.inspectorjack.com
- 2017 SideWinder LTX-LE
This is old but still relevant. Lower RPM of XS825 needs to be considered.
https://ty4stroke.com/threads/turbo-dynamics-clutch-kit-starting-weight-recommendations.150616/
For me, no clutching expert, on Stock Muffler bundle QAY at 73.1g is working well. I believe my 1.6 track required me to run less weight.
Black Teal primary.
Gen2 Dalton Black Orange secondary 6-1
Dalton YSR 35 helix
Black Teal primary.
Dalton YSR 35 helix
- 6K
- 46K
