yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Started maintenance on my chaincase 2019 zr 9000ltd. Just over 3000km
Because of a few topics on ty about top gear and tensioner I payed close attention to those 2 items!
My top 24 gear with 3 oil holes right through gear and bushing was worn and wobbling on shaft!
The inside bolt on my tensioner was backed out 2 full turns.
I will be replacing top gear and tacking screws
Just want to say thanks to all who shared this issue here on ty! You guys may have saved me from a breakdown next season!!!
number1kyster
- Dec 10, 2004
- Vermont
- 2018 SW RTX SE
Check your driveshaft bearing too. Mine was sloppy on my 2018 with only 1,500 miles.
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Thanks I checked theCheck your driveshaft bearing too. Mine was sloppy on my 2018 with only 1,500 miles.
Chaincase side so far all good!!! I will the doing the clutch side tomorrow ( inspecting, popping off the bearing seals and repacking! Also going to look at locking the lower bearing behind the brake so it doesn't spin on the shaft if it hasn't already!!!
number1kyster
- Dec 10, 2004
- Vermont
- 2018 SW RTX SE
I was going to lock mine to the shaft but it was too late.
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
My fingers are crossed that it's not too lateI was going to lock mine to the shaft but it was too late.
Hammer70
GRIPNRIP
- Sep 6, 2015
- Niagara, Ontario.
I’m also going to check mine and put set screws in for the bearing behind the brake rotor.
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
They start spinning on the shaft at mile 1.
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Lucky I only have kilometers on my sled!!They start spinning on the shaft at mile 1.
I'll see how it looks today I have lock tight bearing retainer I'll add that or will put a set screw in it like hammer 70 is
Mine had 2000kms when I switched tracks, shaft and bearing were fine had zero signs of wear. I put one set screw in to keep it snug. Maybe two is better.Lucky I only have kilometers on my sled!!lol
krm
- Apr 22, 2016
- ny
4 0z of extra gear lube works long time wonders .
stevewithOCD
Yamaha, Make me Come Back
- Jan 1, 2008
- Live CT Ride MAINE
- 900 R
2006 Apex RTX
I will be replacing top gear and tracking screws
It's been said that the Cats aren't having a gear wearing problem so this must be FAKE NEWS...................OR, you're the first with an honest sack to admit there is problem.
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Mine is definitely worn!! I can physically wobble the gear on the shaft!! I had .015" wear on the inside of the bushing!!It's been said that the Cats aren't having a gear wearing problem so this must be FAKE NEWS...................OR, you're the first with an honest sack to admit there is problem.
- 50K
- 228K
