pistol
Nothing in the OD then?
And just to be sure we are talking correctly which one is the tip and which one is the OD. OD is the bottom right hole and tip is the top right hole when looking at the weights on the link below.
http://www.richmotorsports.com/store/vi ... SUP2GXXO48
Turk
Tech Advisor
Read your directions. they have a picture with the names of the holes. i name the holes exactly as they are outlined in the instructions to avoid confusion. this is also peliminary test & weight may be added in the centre or overdrive later as stated in my previous post.
pistol
Yep so tip and OD are correct. Lost me on the arm bit in a post earlier.
"Right now at 5 grams arm & 5 grams tip"
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
arm heel shoulder donkey dork
pistol
hahahah... hey now... your not calling me a donkey or dork are you!!! hahaha
BADSLED
- May 13, 2004
- Syracuse, NY
- 2025 Sidewinder XTX LE EPS
2012 Nytro MC Xpress 270
Did anyone weigh the 1/2" Allen screw? I'm assuming it's about 2 gr.???
SledFreak
- Feb 7, 2005
- Ontario. Canada
Yes 2 grams.. The 3/8's are 1.5-1.6 and 1/4's are .8.
pistol
Which ones are you talking about?
The 3/8's are 3.2 grams
The M5 (heel one) is 2.2 grams
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
he's talking about some allen set screws..
here's something to consider....since the o.d. hole is a mass adder to both the tip and center....keep in mind you are affecting both...since the weight is like a see-saw on the stationary pin...the weight which opposes the o.d. is the heel..the heel obviously having the greatest affect on engagement to 50% shift out and the o.d. having affect from the 50% shift out on..so for example if the heel is empty and the o.d is loaded it would have much more affect at mid and tip weight than if the heel weighted opposing it..
therefore guys like you andy...should try unloading the heel to see the affect on your mid to top pull/rpm's
Turk
Tech Advisor
I tried the nytro with minimal heel weight & od loaded. Even tho it hit target rpm,s it was by far the slowest set up I tested et & top speed wise.
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
Mike....we could end this lively conversation if you'd just get your hands on a pc3'd/ign. moduled and excelled apex and work your magic...
Turk
Tech Advisor
my bud had one & it got stolen.(no insurance)
he likes to play with clutching as much as i do.
pistol
So is with what is being said here it appears that the OD hole is nothing more than a gimmick if weights are being loaded without anything in there. Is that a fair statement?
Turk
Tech Advisor
It gives you the option of adding more mass if needed plus it seems to help any mid-range overrev &/or belt slipping.
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
So turk,do they work as advertised,can they out perform stock weights in the apex,for top speed?Turk said:It gives you the option of adding more mass if needed plus it seems to help any mid-range overrev &/or belt slipping.
