vodoo child
- Oct 29, 2005
- Palmerton Pa.
- 2018 Sidewinder LTX/LE 50th
I have an early build LTX LE 50th. SideWinder. I want to replace the factory drive chain. Partzilla has 3 listed. Do I have any way to know witch chain I need other than opening the chain case and counting the teeth on the chain? I'd like to have all parts on hand before preseason maintenance!
You should have gotten a spec sheet in your paperwork.
Fleecer
- Jun 13, 2014
- 2019 SRX
Stock gears 21/41 is 86 pitch chain. If changing ratio, let us know and we'll advise.
vodoo child
- Oct 29, 2005
- Palmerton Pa.
Dug out the spec sheet from the owners manual I keep in the tunnel bag. Spec sheet p/n 2261-708. 2018 SideWinder L-TX 137 LE EB, 86P p/n 8KC-RAM01-20. Thanks Fellas. Need to also call Travis up for some boggie wheels, the two inner forward ones are shot from my studs!
RAMSOMAIR
Use Doo wheels in that location
fxnytrortxkid
- Apr 19, 2007
- Rensselaer, ny
- 09 nytro rtx
Go to jt atv for wheels. Great option.
RAMSOMAIR
I have JT wheels and rear axle but those two inner wheels get flat spots. Myself and many others have experienced this hence the two inner wheels are Doo.
RAMSOMAIR
fxnytrortxkid
- Apr 19, 2007
- Rensselaer, ny
- 09 nytro rtx
Me nore my father have had issues with ours. I have 1.63” triggers an chisels and they have done well. But I guess can use yellow products. I refuse to use anything from them. Bad enough sleds half green.
Upstater57
- Apr 25, 2021
- New York
- 2022 Tcat EPS,
2014 ZR9000 (sold)
1978,1979,1980 SRX (sold)
Always remember, it ain't easy being green.Me nore my father have had issues with ours. I have 1.63” triggers an chisels and they have done well. But I guess can use yellow products. I refuse to use anything from them. Bad enough sleds half green.
