greatwhite89
- Mar 19, 2015
- Oshkosh, Wisconsin
- 2020 Yamaha RS Venture TF
- www.snowflapjunkie.com
I think you're correct. It is the Japanese version of the Dupont.
Sent from my XT1055 using Tapatalk
Apex1958
Yes called standard hyfax LOL
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
Maybe the single shot willl be better on slide wear. Time will tell.
Apex1958
Put a set a DuPont's on and the hyfax issue is no more. Yes they are expensive but on my Viper I would be on my second or third set of regular hyfax in a season. So its a no brainer for me just not to worry about them is worth the money.Maybe the single shot willl be better on slide wear. Time will tell.
UP Michigan rider
Very nice!! 4 and 6 seems to be the "standard" everyone is using now. I'm not convinced this is the best for long long railroad type trails. Isn't it the deeper or higher the number, the more its going to catch on every rut and "dart" or "catch" every previous snowmobiles trail that was before you? Or at least something like that I can't think today.
rwill2cruz
- Jan 23, 2015
- Sudbury, Ontario
- 08 GT LTX Anniversary
Good on the hex heads...finally. Will these hex heads fit the older sleds?GW no more phillip screws to take out on the side panel to change the oil they are hex heads. Grease fittings in the front end. No more plastic engine cover made out of aluminum now. Heated shield plug in big plus. Seat is higher and the shape is also different. Clutching seems to be smother also this is the first sled out of the 16 new sleds I have owned that when loading on the trailer the first time, just gave it a little gas and away it went also backing off was the same I was amazed. I have 6” and 4” carbides on the front and thought I wasn’t going anywhere on the concrete. I have 85 lbs in the front air shocks so the ski pressure should be there.
Apex1958
Yes my dealer changed my 06 to the hex heads.Good on the hex heads...finally. Will these hex heads fit the older sleds?
rwill2cruz
- Jan 23, 2015
- Sudbury, Ontario
Would you have a part#? The parts cat only shows to 2015. 2015 shows 90109-6220-00Yes my dealer changed my 06 to the hex heads.
Apex1958
Should be the same as the new sleds but I will check with my dealer.Would you have a part#? The parts cat only shows to 2015. 2015 shows 90109-6220-00
Apex1958
You have the right part number.Would you have a part#? The parts cat only shows to 2015. 2015 shows 90109-6220-00
rwill2cruz
- Jan 23, 2015
- Sudbury, Ontario
