Easy way to drain oil
Nice trick. I will be using this my self and giving one to my Arctic Cat buddy.
You cut that hole out of skidplate
I already cut the access hole for the filter and drain. I have no desire to cut another hole in the plate. I would much rather reach in flip a valve and have the oil drain into the same pan that the filter and sump are draining to.
Right .. when do I get mine? :)
Being the perfectionist that I am I have requested an alteration to the adapter.
I have what should be the final version of the adapter here any day now and will get the setup as well as the helix that I have on loan back to you shortly.
Sounds good.. I will need 2 :)
Ok I can see the oil drainage area,but what about the filter,where does it sit,and how much of a peta is it to remove?
Here you go. I have a accessory skid plate which I modded to make getting to access plate easy. Still same 4 screws.
When you look up into the hole created by panel removal this is what you see.
Dont get any easier than that. MNM Snowbeast this is for you!
