sbot69
'14 LTX SE. Ran all day Friday. Saturday dead battery. Jumped, ran but no taillight or instrument cluster. Also melted ground wire going from battery down left side of sled all the way to steering column. Jumped bad wire. Won't start, jumped wire gets very very hot. Talked to Bill NoWay from Facebook said to look at wires from starter. How do you get to starter and where is it. Thanks
grizztracks
TY Advertiser
- Feb 24, 2005
- Scio, NY
Does the starter turn over the engine?
sbot69
It did when I jumped it. After it stated I had no taillight or instrument cluster. Found blown fuse for taillight, replaced. Now won't turn over and ground getting very hot and jumping when trying to start. Bill Noway thought to start with wired going to starter. Not sure how to get to it or where it's at
grizztracks
TY Advertiser
- Feb 24, 2005
- Scio, NY
You can get to the starter through the bottom plate that accesses the oil filter. It almost sounds like you had a starter relay failure that kept the starter engaged while running. The relay is located at the battery and might have fused it's contacts together. I'd check the relay for proper operations. Also check all ground termination and make sure they are tight.
The wire going to the starter is a positive feed that gets it's power only when the starter relay is engaged. The ground to the starter is provided through the engine block and the large battery ground wire is attached to the block just behind the starter. If you look between the two clutches you can see the wires and the end of the starter. After checking starter connections check the starter operation by jumping across the two large terminals on the relay to see if it will roll. The magnets in the starter may have come loose and locked up the starter.
sbot69
Going to get started later today. Will post what I find as I go along. This is my second starter. First one went first day after buying it Feb of '14. Thanks for all your time grizztracks.
sbot69
Think I found my problem...Main ground cable going from battery (6 ga.) to front of machine is disconnected. Found nut in belly too. Where does it attach? Thanks again for everyone's help?
grizztracks
TY Advertiser
- Feb 24, 2005
- Scio, NY
Without that wire the current will travel through the smaller ground and overload it. The main battery ground attaches to the motor near the starter.
sbot69
Just can't seem to find the damn stud.
grizztracks
TY Advertiser
- Feb 24, 2005
- Scio, NY
I just checked and it should be under one of the starter mounting bolts.
grizztracks
TY Advertiser
- Feb 24, 2005
- Scio, NY
A lot of reports of loose bolts on these Vipers. Beer sales must be good in Thief River Falls
sbot69
Yup. I found picture of it. Starter was replaced first season'15. Must have been sitting on there but finally came free. Dealer simply did not hook it up. Thanks again for your time and help.
Wow nice job Grizz. Who would have thought.
