roadking
- Jan 8, 2017
- minnesota
- Yamaha sidewinder
it was 17 below when mine acted up.
Mighty
- Apr 17, 2003
- Grand Ledge Michigan USA!
- 22 Mach Z
23 Sidewinder SRX
This happened to me when I lined up to race my buddies 800 etec yesterday. I was leaning forward and grabbed the throttle and it cut out. I was thinking it was the angle of hand, adjusted and grabbed the throttle again and it cut out again. The best description I can give is it was like the kill switch was turned off and on. I stopped as did my buddy. I sat normally on the sled as I would just riding and hit it a third time and all was fine. Yes, I beat the etec
But it is one strong sled keeping with me for several feet out of the hole until I start walking away. This was with 140 miles on the sled. First and only time I had any issues. Sled is stock with cat rollers and 144 1.325 studs.
plake
- Apr 26, 2016
- Sheboygan
- Sidewinder LTX
140 miles on mine when this first started. I never grabbed the throttle from a stop, no studs so not sure mine wouldn't do the same. Guessing you will see it again, it seems intermittent, hardest thing to fix.This happened to me when I lined up to race my buddies 800 etec yesterday. I was leaning forward and grabbed the throttle and it cut out. I was thinking it was the angle of hand, adjusted and grabbed the throttle again and it cut out again. The best description I can give is it was like the kill switch was turned off and on. I stopped as did my buddy. I sat normally on the sled as I would just riding and hit it a third time and all was fine. Yes, I beat the etecBut it is one strong sled keeping with me for several feet out of the hole until I start walking away. This was with 140 miles on the sled. First and only time I had any issues. Sled is stock with cat rollers and 144 1.325 studs.
plake
- Apr 26, 2016
- Sheboygan
- Sidewinder LTX
No answer from dealer yet. Guess no one else having the issue, thread died.
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Thanks for update.. let us know what you hear!
Keith Schmitz
- Jan 12, 2015
- Dousman Wi
- APEX
Mine is going in Sunday. I made my dealer aware, but he said I'm the first one he's heard of with this issue.
Mine should have been dropped off at dealers this morning but highways are all closed due to weather. Not sure when it will go in now, butI'll update with any new info when I'm able.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Good chance it is the first.. Hope you guys get these figured out.Mine is going in Sunday. I made my dealer aware, but he said I'm the first one he's heard of with this issue.
Frozenstiff
- Dec 24, 2009
- Prescott, Ontario
- 2013 Arctic Cat Turbo
Seems to be the standard answer. With to-days technology, there is no reason whatsoever that all the dealers in the world could not be plugged into a world wide data base. Our sledding season is way to short, to spend half of it having problems, that should have immediate solutions. After all, this is 2017. Wake up Yamaha, and get out of the dark ages.Mine is going in Sunday. I made my dealer aware, but he said I'm the first one he's heard of with this issue.
- Sauk Prairie, WI
- www.ty4stroke.com
Jim, Give me a call. You have my #Mine should have been dropped off at dealers this morning but highways are all closed due to weather. Not sure when it will go in now, butI'll update with any new info when I'm able.
Mitch Desorcy
MAX PRO
- May 6, 2014
- Winnipeg Manitoba
- 2014 Yamaha SR Viper LTX SE
Are the Thunder cats doing this? Or is this just a sidewinder issue?
plake
- Apr 26, 2016
- Sheboygan
- Sidewinder LTX
I was wondering the same thing, tried to look at some of their forums but didn't find anything. Not to familiar with their sites however.
ricardo
- Nov 27, 2008
- Ironwood Michigan
- 2017 Sidewinder STX-DX 2017 SkiDoo TNT850
My STX-DX did the same thing once, at 19 miles, drove slow for about a mile thinking "Here we go with the problems", and when I hit it again it cleared up. Hasn't done it again, over 900mi now.
roadking
- Jan 8, 2017
- minnesota
- Yamaha sidewinder
cut out Friday but not Saturday
going into the dealer Monday
tedgoesfast
The only way it can be dionosed is with lab scope if tps dropping out happening to fast to set code also could be in boast protection seeing something it doesent like and shutts it dfown for protection interesting issues looking forward to finding fix
