Tcat100
grow smaller handsChecking to see if anyone has installed the OEM power steering on a 2018 Sidewinder. Would appreciate any helpfull info
Trussman
JAFO
- Mar 18, 2007
- WI
- 2004 Viper S
2017 'Winder
2022 SRX
...........and a third one wouldn't hurt either......grow smaller hands
Big Daddy SRX
- Feb 24, 2006
- Reese, Michigan
- 2018 Sidewinder LTXDX,2014 SR Viper, 2012 Vector LTX, 2011 Apex XTX,
- Reese, Michigan
- AOL
- reesetrailer@aol.com
9 pages of reading will get you your answer. Yes it can be done. I just wanted to verify that there were no problems on a 2018, didn't see anyone actually say they did one.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Can be done.Checking to see if anyone has installed the OEM power steering on a 2018 Sidewinder. Would appreciate any helpfull info.
The 17 and 18 model year sleds require a jumper harness to be made to connect. They have the olders style handle bar controls and new harness won't work with those years unless one gets all newer handle bar controls and harness.
19 and 20 model years have current hand controls and either harness replacement or jumper harness to make work.
22 and up are just plug and play.
The connector part numbers required are in the pages of this thread.
Big Daddy SRX
- Feb 24, 2006
- Reese, Michigan
- Reese, Michigan
- AOL
I have read all pages numerous times but didn't see anyone actually say they installed one on a 2018. I wanted to ask before I ordered the parts. Thanks to all who took the time to really dig into this installation and share their findings here on TY !!
Tcat100
it will work. you just need to read up on the connectors and make the jumper harnesses (one for power, and one for speed signal - very simple) Connector part numbers and sourcing is here. All the information you need to do this is in this thread. Take the time to read it thoroughly and you will have no issues. Feel free to pm after you get the parts and are ready to do the install if you have further questionsI have read all pages numerous times but didn't see anyone actually say they installed one on a 2018. I wanted to ask before I ordered the parts. Thanks to all who took the time to really dig into this installation and share their findings here on TY !!
Big Daddy SRX
- Feb 24, 2006
- Reese, Michigan
- Reese, Michigan
- AOL
02ViperMody44
- Jan 26, 2009
- Utica, NY
2013 Yamaha XTX
- Old Forge, NY
- YAHOO
- ramody44@yahoo.com
Has anyone looked at the description of the '25 EPS unit on the new sleds. It almost sounds like it may not be using any imput from the ECU...plus it sounds like it's lighter. May have a stand alone control module. Early speculation??? Would be nice if they specifically made a kit for retro-fit.
YAMAHA VARIABLE ELECTRIC POWER STEERING (EPS)
Yamaha's newest generation of Electric Power Steering (EPS) has reduced weight by over three pounds and incorporates a "brushless" DC motor for improved reliability and performance. Variable Assist EPS utilizes a magnetic torque sensor that measures steering input based on torsion or 'twist' of the steering post, which is calculated from handlebar input and ski resistance. This data is suppled to an integrated control module which, in turn, signals the brushless servo-motor to assist the steering through its powered, worm-gear drive assembly. All together it gives a more balanced, natural feel or 'connection' to the terrain, and effectively reduces the steering effort required while enhancing predictability for greater rider confidence and less fatigue.earthling
Thats the way they always worked, basically, thats how all electronic power steering works. The EPS doesn't need to talk to the ECU, it just needs to receive the canbus messages for speed which are on the canbus wire pair.
WinderFab
- Mar 1, 2009
- Woodbridge, ON
- 2020 Sidewinder Ltx GT
That is comparing to the earlier apex/vector eps units, no difference between the SW years eps.Has anyone looked at the description of the '25 EPS unit on the new sleds. It almost sounds like it may not be using any imput from the ECU...plus it sounds like it's lighter. May have a stand alone control module. Early speculation??? Would be nice if they specifically made a kit for retro-fit.
My eps parts are in, install to come soon.
02ViperMody44
- Jan 26, 2009
- Utica, NY
2013 Yamaha XTX
- Old Forge, NY
- YAHOO
So no change from the previous SW powersteering...ok. Never read up on the previous year model's PS description. So I won't pull the one out of my '13 Apex...Haha!That is comparing to the earlier apex/vector eps units, no difference between the SW years eps.
Anxious to see how it works for you.That is comparing to the earlier apex/vector eps units, no difference between the SW years eps.
WinderFab
- Mar 1, 2009
- Woodbridge, ON
I had a 11 apex and had the opportunity to try a esp SW, even though it was only for a few minutes there’s no comparison between the two, the apex was nice but the SW eps brings it to another level.Anxious to see how it works for you.
DennyTuna
- Jan 28, 2017
- Ohio
- 18 Winder LTX 50th
16 SR Viper RTX (red)
02 SX Viper ER (red)
97 SX Vmax 600 (red)
Well, I took the plunge and ordered the parts to do this conversion. This will be on an 18. Thanks to all that put in the effort to make this happen!
Hammer70
GRIPNRIP
- Sep 6, 2015
- Niagara, Ontario.
Keep me posted WinderFab I’m curious.That is comparing to the earlier apex/vector eps units, no difference between the SW years eps.
- 6K
