Mad Russian
If you put a agressive carebide, or an aftermarket skis the power steering does almost nothing. I got usi skis and my buddy had the simmons and it felt like we were trying ti turn a semi truck. power steering only works great with the stock skis and stock 4 in carbide. The problem is with the stock set up it just pushes way to hard. Just my own expireince!
Turk
Tech Advisor
I dunno about that. I am running usi vx301 with 8" stud boy shaper bars & it turns pretty easy.
Mad Russian
Well its fine if im going over 30 mph. At slow speeds is weare we were bouth having the problem. I cant see both of us having bad power steering units.
Rick27
I run simmons Gen 1 with 6 inch carbides and one hole up on the limiter and it steers pretty easy.
RollRite
- Dec 16, 2004
- Pickerel , Wisconsin
- 2011 Apex
I run double 4" slimjims and it steers easy at high and slow speeds.
BlueApexXTX
I am running Powder pro skis with 9.5 inch carbides.The sled handles and steers great in all conditions.No darting an steers easy.Great combination.
Mad Russian
Well maybe i have a problem then. Hmmmmm ?!
studdog
An advantage of the EPS should be that you can run a more aggressive wearbar for high speed handling and still have easy slower speed steering. Before EPS we had to have a compromise of high and slow speed front traction. Am I wrong about this?
Rick27
You are correct!studdog said:An advantage of the EPS should be that you can run a more aggressive wearbar for high speed handling and still have easy slower speed steering. Before EPS we had to have a compromise of high and slow speed front traction. Am I wrong about this?
Terminator
Rick27 said:I run simmons Gen 1 with 6 inch carbides and one hole up on the limiter and it steers pretty easy.
X2
- 9K
- 29K
