Evac installed pictures?
Paul RX1
New Brunswick
I'm installing ECP kit , would like to see Evac tubing install pictures...I searched the site it talks about pictures but dont see any? can someone send me some at Bayer123@gmail.com ot tell me were I can view some?
Thanks guy's
here you go
My only sugestion would be to make your drain tube down longer.I made mine about 8 inches long so it hangs down along the bottom of the motor with a garden house on/off valve on the end.Some guys with short hoses freeze up while riding mine has never frozen while riding.
just remove cap on tee every 100 miles or so,and your good to go. usually bout a cap full. + it gives you an extra hp or 2. ;)!
on the bottom pic. the drain valve . is that where you put the pcv valve for draning the line? bought kit from powder muncher and it has the evac kit. there are two lines that run out of stock air box. what do you do with line that was in the bottom?
The small line in the lower right corner is simply a drain for the oil and water that would accumulate in the air box. It is vented to atmosphere.
Freddie
