craigwsrx
- Feb 19, 2007
- Fenton Mi.
- 2017 Sidewinder 27,000 miles
2009 Nytro xtx 31,000 miles
2006 Attak 26,500 miles
2003 RX1 13,500 miles
2000 Mountain Max 14,000 miles
1998 SRX Mountain 17,000 miles
1995 V Max 600
1979 SRX 440
1975 GPX 338
1973 GP 338
I was removing my clutch to disassemble and clean and found my PTO outer bearing wiped out. I have a little north of 27,000 miles on my sled so I'm not complaining, just letting everyone know to check this bearing periodically. It comes as an assembly, part number 8GL-11406-00-00 ($460.99 list). There is an inner bearing in engine lubed by engine oil but this bearing is sealed. The outer bearing has a hard metal outer so I am going to figure out if this bearing can be greased from the outside like they do for the Ski Doo clutch side.
I have replaced these on other Nytros... not sure why some fail with low miles but I have seen them up and over 10000 miles and still running strong...
Deeppow16
- Oct 19, 2015
- Montrose, Minnesota
- 2016 Arctic Cat M8000
2002 Polaris 600 XCSP (Sold)
Well you really got your moneys worth out of that bearing at 27000 miles.
herndonp
- Nov 28, 2012
- Freedom,NH
- 2012 Yamaha Nytro XTX
Partspak has it for $329.42
herndonp
- Nov 28, 2012
- Freedom,NH
You can just buy that bearing 93306-30721-00 for $29.98 from procaliber if its a 2012 or newer Nytro.
Pete
Pete
pedros83
- Nov 19, 2015
- Blackstock, ON
- 2010 Nytro XTX
This bearing located behind the primary?
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
- 2018 Sidewinder RTX
How does that come off the engine once the 4 bolts are removed?
Do you require a puller of some kind?
Funny, I never paid attention to that part thinking that bearing would be lubricated from the inside of the engine.
MS
MS
craigwsrx
- Feb 19, 2007
- Fenton Mi.
1995 V Max 600
1979 SRX 440
1975 GPX 338
1973 GP 338
craigwsrx
- Feb 19, 2007
- Fenton Mi.
1995 V Max 600
1979 SRX 440
1975 GPX 338
1973 GP 338
There are no special tools needed. I used a lady slipper to get the assembly out. I am going to see if I can change the bearing in my old one, not sure if you can on mine. It is a 2009.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
i was curious so I grabbed one from an 05-09 vector. I was able to press it apart. The nytro will have the extra gear on it for crank position sensor. not sure if that gear gets in the way if you tried to press it apart. Don't have any nytro ones laying around to look at.
I have several of the 05-09 vector assemblies here. If you get yours apart maybe measure it. I can see if its the same as the vector. Know I have one from a 300 mile engine.
SnoBird888
- Sep 4, 2013
- Neenah, WI
- 09 Nytro xtx
id be interesting in replacing mine as well in the off season. maybe replace it with a 2012+ version if needed then the bearing can be replaced later instead of the whole unit?
craigwsrx
- Feb 19, 2007
- Fenton Mi.
1995 V Max 600
1979 SRX 440
1975 GPX 338
1973 GP 338
I have a new one coming, and I am going to try to get this one apart to replace the bearing. We'll see how it goes.
Mills
- Dec 4, 2007
- Elk Mound, Wisconsin
- '21 SRX, '14 Viper RTX, '06 Apex, '99 SX 600, '74 TL433F,
Replace mine on my 2008 Nytro with just a press and some tools that I created from aluminum stock to help me get things pressed apart and pressed back together. Take your time have a buddy help you and you can do it in an hour and a few beers.
Mills
- Dec 4, 2007
forgot to mention that I did not replace the whole $300+ assembly. I just used a 2012 bearing and took my time with a press and some tools I made from aluminum to help press it apart and back together again.
Don't buy them from a dealer, get the EOM bearing from www.procaliber.com for half the cost
Dr Ecto
- Jan 22, 2014
So I have been wanting to pull my primary off and grease mine. I assume the seal can be pulled and bearing greased similar to the secondary and speedo bearings? Also where can I get a good primary puller? Have seen lots of horror stories about cheap ones bending or getting stuck in the clutch. Can't tell which ones are good online. Thanks.
