- Jun 28, 2004
- Clinton, Wi.
I usually run a zip tie around the bars and brake lever when doing work on the secondary. Run it tight enough to hold and you can just compress the brake lever and slip it off the lever.
stubby
Thanks Viper Dave and Steiner for the tip applying the hand brake the secondary came off no problem.
kered
- Mar 22, 2014
- Newmarket, Ontario
- 09 Apex GT
Microfiche shows there are two shims and a washer between bolt and secondary? I only had the one shim and washer, am I missing one?
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
Measure Your offset between the primary and the secondary.
It's supposed to be 15 mm. +/- 1.5 mm.
If you're Within the tolerance you're OK
kered
- Mar 22, 2014
- 09 Apex GT
How do I check the offset?
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Norway
push the secondary into the Jack shaft, use a caliper and measure the distance between the inside of the primary stationary sheave and the inside sheave of the secondary clutch. It should read between 13.5 mm. and 16.5 mm. spec is 15.0 mm +/- 1.5 mm
gmfamily2008
now that the snow is gone here.
was just reading thru these posts , seems to be some confusion between driveshaft bearing and the jackshaft bearing . jackshaft bearing is behind secondary clutch on the same shaft and is much harder to replace .
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Norway
Yes it is some work, but easy to do With the right tool.
The procedure is found in my rxrider's turbo garage thread.
Link in my signature.
Roger
- Feb 10, 2007
- Osgoode Ontario Canada
- 2012 RS Venture GT (power steering doesn't work when real cold)
2006 Indy 500
I followed rxrider instructions, made my own tool, and when I had finished, found that it was actually quite easy to do.
lvUP
- Aug 22, 2015
- grand rapids
- Yamaha apex
Pure fear! I have read this many times and I'm a newbie. Changed the exhaust donuts but this looks hard. My Apex has 5200 miles on it and I'm not sure if these have ever been checked. The difficult part looks like the side with the chain case. I saw pictures online on removing the chain case and replacing the lower bearing. It looks hard.
lvUP
- Aug 22, 2015
- grand rapids
- Yamaha apex
Hi, having trouble removing the bearings on the clutch side of the sled behind speedo. Even tried a puller but the puller was small with metal stamped fingers going behind it. Tried some heat, nothing. What else to try and remove the bearing?Im not sure,as I havent done one....but it looks like it can be PULLED off the shaft...someone else may chime in here whos done one...
just another reason to grease it....since this will reduce the chance of ever having to change it.
Dan
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Norway
Are you talking about the left drive shaft bearing?
There are two torx set screws on the bearing, you need to access them from inside the tunnel.
Loosen the set screws and you can remove the bearing
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Norway
You may find all you need in rxrider turbo garage thread, link in my signature.
http://www.ty4stroke.com/viewtopic.php?t=47473
lvUP
- Aug 22, 2015
- grand rapids
- Yamaha apex
Loosen the set screws and you can remove the bearing![]()
I wish you lived nearby! I owe you a beer. Your totally correct. The garage is starting to get cold and I'm nowhere near being done.
lvUP
- Aug 22, 2015
- grand rapids
- Yamaha apex
Thanks, there is a lot there in your site. I'm trying to change the lower bearings on both sides of the sled, clutch and chaincase. It seems I need a 37mm wrench to remove the jackshaft however I can't find a wrench that large. Been to 3 stores. Also, even if I get it off where would a buy a deep well socket so I could get a torque wrench on it? It s a Yamaha Apex 2006
- 30K
