snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Well last night a shawns house,where we have been rebuilding this wreck,we hit the correct mix of tweeks to make this bad boy rock. Shawn drilled a new hole in the MTX drop down bracket,1" higher up just under the support,and it was the perfect solution. As sled now sits 2" lower than it did as an MTX,close now to stock LTX,man what a difference a one inch hole makes,we left the front hole along,sense we would have had to drill out one of the pierced rivets,and been to close to drivers with rail tips.For some reason,just dropping the tunnel down over the skid this far,tightened up the track,must be just the geometry difference,whatever it is,we like it. So we set the tension of track with 20lb weight,to 1.25" a little tighter than most woud set it to,but sense it was racheting so bad,we wanted to start there. It was a good choice,next removed the plastic blocks completely,and left rod in place,i have 8.4 dia TD 4 wheel kit,so mine will hit wheels if rod is not in place. Took 3 grams out of STM tips,or removed one tungsten from tip,and replaced with 4 washers,left straight 38 and red spring in its pos. in secondary,put worn 8JP back on,well when I say worn,it only lost .010 thou from width compared to brand new belt. Ok time to give it a spin,my driver comes back in,#*$&@ this thing rips now,no rachet,and pulls skis two feet now while hitting this small bump that would of only before given him 2" of lift. Ok now for the good news,he called me this morning at 9am,and could not stop talking great things about how he now loves it,and before hated it. Man its now a hand full when you hammer on it,from a roll,or dead stop,it now from a dig,carries skis 2" for a long ways,no rachet at all,and runs 9100 pulling so hard,he said its scary,now he said we are carriening so much speed into each corner you have to be on your game. And the rpms may even climb up more,if he could hold it open longer. Sense the rpms now want to be between 9150-9400 with this tune,well it may be scary now on such hard conditions as they had this morning,he said they had to pass the groomer as they are still gearing for this weekend. Well if he makes it home safely tonight,i assume the stories will be better,than what I heard early this morning. At any rate he feels now,we will be able to keep that MTX tunnel,as it seems to work well now.
