DranttelSS
- Oct 9, 2014
- St. Peter MN
- 2007 Yamaha Attak
Yeah, Im probably going to have to order that windshield now.
Looks good!
Looks good!
Looks good!
They don't give us much choice but once I modified it overall I think this will really do the trick. Sporty and somewhat functional.
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
I did the same, works great...Lots of guys are doing this...They don't give us much choice but once I modified it overall I think this will really do the trick. Sporty and somewhat functional.
DranttelSS
- Oct 9, 2014
- St. Peter MN
- 2007 Yamaha Attak
Now that I installed the GPS on my sled it sticks over the top of my super low Viper windshield. I think this shield should hide it better.
Phatboyc
- Apr 2, 2007
- Ottawa, Ontario
- 2022 Sidewinder
So for 760 miles and the Igrips are doing well.
Which model did you get? From what I understand these are new model for snowmobile only application.
I use the ST22R, for 1 1/4 tracks and taller and the ST18R is for under 1 1/4 tracks. The 22 is MM of length as well as the 18 is MM of length of stud. BTW The key to get them in straight is pilot drill with 1/16 bit first.
aquaticlaker
- Feb 21, 2009
- Green Lake WI
- SIDEWINDER L‑TX LE 50TH
- Green Lake Wi
Just added these to buddy's 2015 vector. Used the St22R.
Nice work!!
Sledroll
- Dec 19, 2005
- Muskoka , Ontario
- 2022 SRX LE
2017 SW LTX LE
I ordered that windshield also .I did the same, works great...Lots of guys are doing this...
Back ordered from Yamaha Canada .
DMCTurbo
- Nov 12, 2005
I had it from my viper, tried selling it on kijiji but no takers so figured I'd try it on the sidewinder and it looks and works great. Everything seems to be backordered from Yamaha these days...I ordered that windshield also .
Sledroll
- Dec 19, 2005
- Muskoka , Ontario
- 2022 SRX LE
2017 SW LTX LE
I am switching out the tunnel bag for the seat bag , to get more storage space .I had it from my viper, tried selling it on kijiji but no takers so figured I'd try it on the sidewinder and it looks and works great. Everything seems to be backordered from Yamaha these days...
Do you know if the SW windshield bag fits with that Viper windshield , even though it states for mid and high windshields .
I tried all over to get the red tunnels flares you have , but no luck so had to settle for black .
They look ok , with the red snow flap.
Just trying to change the look , so I can pick mine out in a crowd of Red/white LTX-LE 's !!!!!
Sledroll
- Dec 19, 2005
- Muskoka , Ontario
- 2022 SRX LE
2017 SW LTX LE
Sledroll
- Dec 19, 2005
- Muskoka , Ontario
- 2022 SRX LE
2017 SW LTX LE
Pstn head
Very nice!!! Go with the red ski tips IMO but then again pretty cool red on one and white on the other, diffrent for sure.
I decided to add the cold air intake to my SideWinder from Alpha PowerSport
Currently running the Stage 3 Evo Flash and added a K&N pre-filter #22-8044PK from Ulmer Racing.
Fairly easy install.
I added clamps on the rear and front nipples of the Alpha intake to secure them in place when pushing on the hoses from the sled because the nipples wanted to push in. I also added a pre-filter to the intake filter, this is not provided from Alpaha. I like the idea of keeping small participle and belt dust out of the turbo.
- Remove Side Panels and unplug hood harness, removed hood.
- Remove the 3 Torx Screws from the underside through the belt guard.
- Pull back on the intake box and it will pop off the main intake tube.
- Pull out the rear tube that comes from the motor valve cover. This will need to be shortened to go onto Alphas rear nipple on the new intake.
- Remove the front clamp and pull this off to the side. This will go on the front Alpha intake nipple
- Put all the parts in place, lightly attach everything but do not tighten the main clamps until you have it in your desired location. I would also suggest putting the pre-filter on before sliding the filter onto the Alpha intake plenum.
