super_rash
- Feb 24, 2014
it's not a motocross, not much dust going in that filter anyway...you want to prevent snow dust IE water going in though..
justin1620
- Feb 3, 2014
- Rainy Lake, Ontario
- Sidewinder
- www.rustymyers.com
2017 Thundercat vs 2017 Ski Doo 850
Yes those need a filter! LOL . Then again if it was me and I knew it was going to be close race maybe the girls nylons stretched over the cage would be good enough for a run or two!
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
what would you put in its place,todays race was dirty as hell and even dusty as most of the fast sleds were 144-163 " long,with 2" to 3" tracks and all hauling the mail in 400 feet,track lose grass,and mu SW could not get out of its owne way,with 192 studs,but zero transfer,finally I loosened my straps all the way out,now we are talking,my blocks had been gone for 3 weeks,only thing I changed in primary was spring,left the air filter along,never thought about that having any effect,my sled rolls real free.When you guys are racing other brands first thing you should do for power is toss that air cleaner as far as you can.
Thunder66
- Nov 5, 2015
- Holly Michigan
- 2012 Yamaha Apex
I'm curious as to why you think the filter is a problem?
Because I saw the difference in and out. It's free to just try and if you like it make something more permanent,check afr etc.I'm curious as to why you think the filter is a problem?
For dirt I would rig a K&N up. Be so easy to do. No Sidepanel, no cover. For snow/ice I would bypass the whole box and get air from under bars or right out the side with frog skin filterwhat would you put in its place,todays race was dirty as hell and even dusty as most of the fast sleds were 144-163 " long,with 2" to 3" tracks and all hauling the mail in 400 feet,track lose grass,and mu SW could not get out of its owne way,with 192 studs,but zero transfer,finally I loosened my straps all the way out,now we are talking,my blocks had been gone for 3 weeks,only thing I changed in primary was spring,left the air filter along,never thought about that having any effect,my sled rolls real free.
Thunder66
- Nov 5, 2015
- Holly Michigan
- 2012 Yamaha Apex
I've seen a similar debate for years regarding the backfire screen in 4 stroke mx bikes. Some say it robs power but many experts say it doesn't. Personally I see nothing wrong with the filter set up for the average guy. I have to believe that Yamaha thinks it is the right thing to do to put that filter there.
Yes. Just don't race someone without it!I've seen a similar debate for years regarding the backfire screen in 4 stroke mx bikes. Some say it robs power but many experts say it doesn't. Personally I see nothing wrong with the filter set up for the average guy. I have to believe that Yamaha thinks it is the right thing to do to put that filter there.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
I would run the filter. Have you ever seen what dirt does to a turbo?
I guess it was a mistake even mentioning it. Laugh at the backfire screen example above. Ever ride a WR450 with and without all the nannies? Racing isn't for everyone. Power almost always involves compromises. It's out there and you know so 100% your choice what to do.
Fleecer
- Jun 13, 2014
- 2019 SRX
Have any performance shops run sidewinder on dyno with/without airfilter to substantiate any advantages?
Airfilter actually blocks airflow routed thru clutchguard. Perhaps clutches may run cooler without it?
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
AND I guess the big one for me is does it change AFR??? Lean maybe? Cant image much butHave any performance shops run sidewinder on dyno with/without airfilter to substantiatell any advantages?
rtx moose
- Jul 31, 2014
- WATERTOWN,MN
make me laugh the doo doesn't stand a chance!
Thunder66
- Nov 5, 2015
- Holly Michigan
- 2012 Yamaha Apex
WR450 nannies have nothing to do with the backfire screen. It is obviously totally up to you what you do with your sled but there are a lot of impressionable folks out there that might think they are going to get some great power gain by taking it off and finding themselves very unhappy later.I guess it was a mistake even mentioning it. Laugh at the backfire screen example above. Ever ride a WR450 with and without all the nannies? Racing isn't for everyone. Power almost always involves compromises. It's out there and you know so 100% your choice what to do.
