Kevin
- Dec 20, 2006
- Ottawa Canada
- Sidewinder
With another SW a new thundercat and a 850......No long pulls......Ya right
Mighty
- Apr 17, 2003
- Grand Ledge Michigan USA!
- 22 Mach Z
23 Sidewinder SRX
Is he going to give you a new belt?Looks like no rollers for this weekend
Should I ride with one flat one?
Yamaha Rep says ride it
Kevin
- Dec 20, 2006
- Ottawa Canada
- Sidewinder
No idea
I'll be pushing for a belt and helix since it's already marked
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Interesting. I was wondering if I should be able to spin them. Because the ones in the primary spin freely and am used to seeing that on my other sleds. Actually, last week (prior to my most recent ride) when I tried spinning them on the secondary, none of them did. Wasn't sure if that was good or bad. And as I said before, all ramps had marks on them.
If your not ABLE to spin the three rollers on your secondary clutch.(on helix ramps) Your one lucky son of a B*&%$..
Most have at least one that's floating in mid air. All three will have marks on ramps > that does not mean much.. When that belt engages the rollers are FORCED to touch.
EDIT unless you can not roll them because they have massive flat spots on them..
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
I installed the cat rollers, osp adjuster, and 8DN belt over the weekend. Only one of the stock ones had flat spots. Checking the cat rollers once I got home, I noticed that all 3 were in contact with the ramps.
you?
11yamies
- Nov 28, 2016
- Michigan
- 2017 sidewinder ltx dx
I ordered the Arctic cat rollers last week and just got an email that they are back ordered until 3-24-17. All three of my rollers have flat spots on them at 988 miles. My dealer "Fox motor sports" in Grand Rapids is clueless to any of the issues that are common on this forum. (Very frustrating) With parts supply being depleted Yamaha needs to step up to the plate and offer some solutions before we all have $15,000 paper weights sitting in the garage, and our short winter season disappears.
kylechargerrt
- Dec 8, 2013
- Scotland Ontario
- 2017 YAMAHA SIDEWINDER LTX-LE
1998 MACH-Z
Your best bet for now would be get a hold of ulmer or thunder products, and get yourself some new rollers. Hopfully yamaha comes up with a solution but I have my doubtsI ordered the Arctic cat rollers last week and just got an email that they are back ordered until 3-24-17. All three of my rollers have flat spots on them at 988 miles. My dealer "Fox motor sports" in Grand Rapids is clueless to any of the issues that are common on this forum. (Very frustrating) With parts supply being depleted Yamaha needs to step up to the plate and offer some solutions before we all have $15,000 paper weights sitting in the garage, and our short winter season disappears.
Sent from my SM-G920W8 using Tapatalk
roweboat70
- Jan 25, 2011
- 2017 Yamaha Sidewinder STX-DX
I have rollers from Ulmer and just getting ready to put them in, but how the hell do you get the roller pin out ???
I have the retaining screw removed, but that pin won't drop out.
Mighty
- Apr 17, 2003
- 22 Mach Z
23 Sidewinder SRX
Take a small allen wrench and push it out through the hole on the opposite sideI have rollers from Ulmer and just getting ready to put them in, but how the hell do you get the roller pin out ???
Pstn head
Use a dental tool or a paper clip, there a smaller hole on the opposite side of the roller pin set screw poke the small wire tool and push the pin out.I have rollers from Ulmer and just getting ready to put them in, but how the hell do you get the roller pin out ???
roweboat70
- Jan 25, 2011
Thanks Mighty and PSTN Head.... low light conditions, thought I looked and didnt see the hole on the other side.... got it now thanks.
newtron
- Jan 2, 2010
- 2020 900 ACE Turbo, 2019 SRX, 2018 850 X
I used a magnet to get them out. Works well!
AXR
- May 5, 2007
- Central NY
- Current: 2017 SideWinder L-TX LE
Past: 2015 Sr Viper R-TX SE, 2008 Apex RTX, 2002 Sx Viper, 1997 XTC 600, 1991 Doo Formula Plus.
Talked to my dealer today. He said his rep told him about the flat rollers and said that Yamaha was working on it. So Yamaha does know about it. Let's hope its not a 4 year fix like the viper ecu that still has issues.
SideHogger
- Apr 16, 2016
- upstate ny
- 2017 Ltx-Le Sidewinder
Hauck has rollers now alsoTalked to my dealer today. He said his rep told him about the flat rollers and said that Yamaha was working on it. So Yamaha does know about it. Let's hope its not a 4 year fix like the viper ecu that still has issues.
- 7K
