Super Sled
- Feb 25, 2009
- Summit X
Re: the new edition of snowmobile mag has a compresor
Yep, from TeamFAST industries. Supposed to be able to adjust Mega Float psi on the fly, as you fly down the trail. System is called TeamFAST COMPAC air system. Should be sweet. This may just push me into a Mega Float with this on the fly air system.......
harpo said:SharkAttak said:cannondale27 said:I wonder if anyone has ever put a air compressor on a float?Might work well to adjust the airpressure as your riding like the M10.Why not on front also?
adjust on the fly, good idea![]()
The new snowmobile mag i looked at today had a small compressor that mounted on side of floor runners to adjust shocks
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
TeamFAST Compac kit information attached! Ulmer Racing will be a distributor for this!
Also we have our EPA kit available as well with some new refinements from last season!
http://www.ty4stroke.com/viewtopic.php?t=92462&highlight=
Super Sled
- Feb 25, 2009
- Summit X
Hey Allen, when each kit be available and what coats be for each?
And I seriously don't mean to pit you on the spot by asking this, but which kit do you recommend?
- Apr 17, 2003
- Menno, SD
- Menno, SD
The Ulmer kit is available now for $395. The TeamFAST kit I believe will be available at the end of October and I do not have a cost yet at this time.
Both kits virtually do the same thing, it is just if you want the compressor setup hidden under the hood or if you want it mounted out on the rear of the tunnel area.
Super Sled
- Feb 25, 2009
- Summit X
Srxspec said:The Ulmer kit is available now for $395. The TeamFAST kit I believe will be available at the end of October and I do not have a cost yet at this time.
Thx Allen, appreciated. Will they both be rated to be "on the fly" systems, where you can adjust the air while cruising down the trail?
I know yours has a handy push button that is convenient. Is the TeamFAST model's compressor button down on the tunnel?
