ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
I dont think any dealers are pulling the mufflers to check chain tensioner....doubt that very much.
You would think the person installing the chain tensioner at factory would tighten it, even if the dealer is supposed to check this. Its like most the bolts/clamps on these sleds...all not tightened properly. Comes back to quality control in TRF.
5valve
- Feb 3, 2013
- N. IL.
- Nytro, IQR, Redline’s, trailing-arm Polaris’s
5valve
- Feb 3, 2013
- N. IL.
That’s the difference between a good & bad dealer
yamahaguy
Ride SAFE
- Apr 20, 2014
- 2015 Yamaha MTX LE with MPI
My dealers mechanic has OCD. He used to ride a Viper now he rides a sidewinder.. It definitely helps when your mechanic loves the sport Rather than just a place to work until a better job comes along. Maybe when choosing a dealer the first person you should start talking with is the mechanic rather than the salesman. Just a idea.
DranttelSS
- Oct 9, 2014
- St. Peter MN
- 2007 Yamaha Attak
Its not that hard to believe. It happens on EVERY new sled here. Were not all bad
RollinTurbo
- Jan 8, 2018
- Maine
- 2018 Yamaha SideWinder B-TX
I'm "A" guy Ken brought back .... he happened to be out on his side x side headed home and he was nice enough to give me a tow...
My tensioner was in place and NOT the source of failure... they showed me all parts and clearly was a result of the reverse actuator and gears not playing nicely
krm
- Apr 22, 2016
- ny
I was pulling in from a ride when he was headed to get you .Great crew there .Headed back Sun - Fri ,Starting in Sherman ,heading North ,Then back .Good luck,hope all's good now .?I'm "A" guy Ken brought back .... he happened to be out on his side x side headed home and he was nice enough to give me a tow...
Al Bundy
- Mar 4, 2016
- Maine
- 2004 Rx Warrior
My sled, last year, after a fella in a side by side with tracks pulled me to Wilderness Variety.
Thank goodness for folks like that.
XP123
- Dec 25, 2016
- Chautauqua NY
- Sidewinder XTX LE 137
Wow nice low rider. Do you let out all the air when you stop so it's easier to get on and off your sled? Can you make it hop down the trail?My sled, last year, after a fella in a side by side with tracks pulled me to Wilderness Variety.
Al Bundy
- Mar 4, 2016
- Maine
- 2004 Rx Warrior
Broken rear arm on M10 before I put the M20 Airwave in!
- 11K
