bottlerocket
Does anybody have any pics with one of these on? Yamaha has a bunch of stuff on sale till the end of the month. Part number #SMA-8GL83-DL-00. Thanks
SSX600
- Feb 13, 2010
- Richland Center WI
- 2010 Nytro XTX, 1997 Mtn Max 600, 1998 SSX600, 1975 SM292F, 1987 Inviter
bottlerocket
Thanks how does it attach to the sled and how easy is it to take off? Bigger then I thought.
T T Bone
Better picture
They are very easy to install and remove when needed.
bottlerocket said:Thanks how does it attach to the sled and how easy is it to take off? Bigger then I thought.
bottlerocket
My question was how do they attach?
Bister
- Nov 17, 2010
The front edges just clip on under the edge of the side panels and then you drill 2 holes on each side and pop rivet snaps by your feet and it just snaps on and when you take it off, you only have the 2 snaps on each side you would never notice.
sgilbert
it is mint compared to the apex. fits/looks good. stays snug. holds six pack easily, no shaking
phatkid
will that still fit with a trail tank???
upei93
- Apr 27, 2008
- Dalhousie, NB
- 2015 Viper X-TX LE MPI turbo
2009 Nytro XTX
phatkid said:will that still fit with a trail tank???
To fit a trail tank you would have to come up with a way to modify to front tabs that hook onto the plastics that are replaced by the tank.
bottlerocket
Got one coming ~ thanks guys for the great responses as always on TY4!
09nytro
It should it just hooks on the bottom side of the hood shouldn't have to do anything to itupei93 said:phatkid said:will that still fit with a trail tank???
upei93
- Apr 27, 2008
- Dalhousie, NB
2009 Nytro XTX
09nytro said:It should it just hooks on the bottom side of the hood shouldn't have to do anything to itupei93 said:phatkid said:will that still fit with a trail tank???
I believe it hooks onto the plastic peice that you remove when installing the trail tank...trail tank is to wide for the clips to fit although I could be wrong...
09nytro
No i have that bag and it hooks to the hood those clips dont stay very well sometimes they slide out not all the time its a very nice bag i like it don't use it all the time only on long trips
this is the first thing I did to my nytro. great bag
upei93
- Apr 27, 2008
- Dalhousie, NB
2009 Nytro XTX
I have this bag and it hooks to parts 8 and 9 which are removed when you install the trail tank...not sure how you would hook it to the hood...BTW mine never slips.
- 32K
