jcavana71
If you look under the 09 XTX fische it's listed as Heat Exchanger Kit, Item 62: 8HA-124A0-00-00
I bought mine from Kellys Cycle Centre.
http://partsfinder.onlinemicrofiche.../Yamaha_OEM/YamahaSnow.asp?Type=13&A=419&B=35
ShootToThrill
I never had an overheat issue to begin with, but looping coolant through the tunnel protectors keeps the ice from bridging across and building up. That's what the factory should have done, it takes care of 3 complaints.
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
There's many things the factory "should" have done...but they just don't.
Daranello
Suspended
Yellowknife said:Daranello, is it simply the 1 part listed under the MTX micro fische or is there an actual 'kit' that is an all-in-one with a single part number? (do you have it?)
It's one part# same as the US. Comes with everthing you need an well worth it. Part was if I remember $190. I'll see if I can find my bill.
Daranello
Suspended
This cooler I would have gotten for the ice issues
http://www.ty4stroke.com/viewtopic.php? ... ght=cooler
Daranello
Suspended
Part #62 for the kit: http://partsfinder.onlinemicrofiche.com ... &A=405&B=7
Last year the part was way less expensive in Canada. Like I said under $200
Yellowknife
- Jan 25, 2004
- Yellowknife, NT, Canada
- www.youtube.com
Thanks guys - never seen Yamaha list the same part number for both the U.S. and Canada. Likely the solution i'll implement. Might as well remove the tunnel protectors while everything is out as well. Anyone know if you can still fit the accessory 1.5" lugged track from Yamaha/Camoplast in there with the heat exchanger kit?
ShootToThrill
Yellowknife said:Thanks guys - never seen Yamaha list the same part number for both the U.S. and Canada. Likely the solution i'll implement. Might as well remove the tunnel protectors while everything is out as well. Anyone know if you can still fit the accessory 1.5" lugged track from Yamaha/Camoplast in there with the heat exchanger kit?
Why not? The cooler is factory on the MTX sleds.
Yellowknife
- Jan 25, 2004
- www.youtube.com
Wondering because the amount of clearance between the track and the tunnel on the MTX is much higher than the XTX - at least when comparing my 08 MTX to my 09 XTX.
When ice lets go in the tunnel while riding on my MTX, it punches through and clears out. When it lets go on my XTX, it jams the track up solid. Dangerous for sure, doesn't make me very happy when that happens. Huge clearance difference under there.
mach9
I've gone over this in my mind for a couple seasons.
IMHO...
Yamaha's mountain rear cooler kit.
Pros, better location to keep snow/ice away up front near the front exchanger. $200 or less.
Cons, only on one side, why?
And build up can still occur further back.
Various Rear exchanger kits. Or home made ones from other sleds.
Pros, cheap and less build up at rear. (keeps the 30lbs of ice off your tail)
Cons, overheating may still occur on front exchanger in powder @ -20.
Extra various hoses and bits required.
In the end if I do anything. I'll call MPI and chat with them more about the full length exchanger kit. It seems to fix all issues. Comes as a kit and some install support. I think that is worth the extra $200+
Cheers
IMHO...
Cheers
Summitseeker
- Sep 14, 2009
My Nytro overheated for the first time ever this weekend but only because I was towing a 2011 800 Etec behind me going up hill! LOL
Yellowknife
- Jan 25, 2004
- www.youtube.com
what happened to the etec to make it inoperable?
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
overheat'n
first...a partial tunnel block off will stop most of the icing and aid cooling..you need to equalize the differential between the hot muffler and cold tunnel...second...
you might have an air bubble... get the nose in the air and bleed...also dilute the coolant..if its straight it will give the lowest freze protection but far less cooling..
Try to keep your speed when pulling the etec up the hill under 80mph as your scaring the S-K rider anyways. LOLSummitseeker said:My Nytro overheated for the first time ever this weekend but only because I was towing a 2011 800 Etec behind me going up hill! LOL
yamahabandit
I think you need to keep it over 80mph because those 800's are fast!bottlerocket said:Try to keep your speed when pulling the etec up the hill under 80mph as your scaring the S-K rider anyways. LOLSummitseeker said:My Nytro overheated for the first time ever this weekend but only because I was towing a 2011 800 Etec behind me going up hill! LOL
- 11K
