scuba335
- Dec 8, 2007
- Boston, MA
- 2018 Sidewinder LTX-LE
Possible bad O2 sensor. I had to replace mine.Everything on mine works except the afr . Always shows 0.0 . I must have a different problem?
Bosch 4.9 LSU 17025 sensor
zxtyler
- Dec 12, 2020
- Michigan
- 2020 SRX
Did it show you a code?
scuba335
- Dec 8, 2007
- Boston, MA
Yes...Sd_24Did it show you a code?
Would stay on constantly
zxtyler
- Dec 12, 2020
- Michigan
- 2020 SRX
I’m not getting a code but thank you.
RK Performance
- Feb 11, 2018
- UP
- 2017 T-Cat
2017 ZR9000RR
Where are you guys mounting your Wideband Modules? Anyone have any pics of the connections and location? Also with lighted handguards I suppose I need a splitter for the accessory plug if i want to keep running them with the O2?
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Page 28 in gap manualWhere are you guys mounting your Wideband Modules? Anyone have any pics of the connections and location? Also with lighted handguards I suppose I need a splitter for the accessory plug if i want to keep running them with the O2?
Janne339
- Oct 31, 2015
- Sweden
- Sweden
- 2021 Sidewinder LTX GT
Are the bugs sorted out? Any gain in performance or fuel saving?
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
For fuel this is what we noticed!!!Are the bugs sorted out? Any gain in performance or fuel saving?
I ran with 3 other guys
2 of us run hurricane header pm tunes with closed loop
2 of us run hurricane pm tunes with stock exhaust manifold no closed loop
We ran for 3 days together paying close attention to fuel economy.
All 4 off used exactly the same amounts of fuel at each fill up
3 guys 24/50 and I run 21/38
I am guessing our header tunes are probably are a little harder on fuel? It would have been nice to have a one of us with header and no cl for better comparison.
We have 2 other buddies that been riding together all season.
Both the same set up but one hurricane and one td
Pm tunes ,3 bar, trail mufflers , bov, ...
The hurricane guy has closed loop and the td guy did not.
The hurricane guy with cl was seeing 5 to 8$ less at each fill up.
But hear is the kicker..lol
The same hurricane guy with cl rides with another hurricane guy with the exact set up but no cl and they end up exactly the same at the pumps.when filling!!
As for performance throttle did feel crisp.. we did notice less black sout on the exhaust side lower pannel.
All the guys I know who run the closed loop has no issues. Some who purchased cl early season needed a update and all was good
Imo: -no noticeable change in performance
- Fuel mileage is NOT an 18% reduction as Ben from td stated.
- i do like having afr displayed on my gauge
- in warm weather riding we did have less exhaust Soot on panel and no more warm weather backfiring. So it definitely runs leaner and cleaner
Hopefully other with cl chime in with there experience and comparisons
yamamarc
Why did the early season CL need updates?
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
There were a few bugs at first mainly because incorrect flashing procedure from what I understand( needed to disconnect the module when flashing)yamamarc
Some (myself one of them )not having afr displayed on gauge!
Some guys ended up with a pile of ghost code that need to be cleared if they flashed with module plugged in.
justinator
- Mar 25, 2007
- Maine
- 2023 Arctic Cat Riot 9000
I for one noticed no difference in fuel economy. The claim seemed like a best case scenario , certain condition potential up to 20% which I understood as basically 0-20%. Both tuners utilizing gap software made the claim in their descriptions on the website.For fuel this is what we noticed!!!
I installed my close loop as soon as they became available , never disconnected my AFR module, and mine has been problem free...I must have got lucky
HMTurbo
- Dec 5, 2017
- Midwest
- 2018 LTX-Le
For the Hurricane closed loop system what is the difference between the Air Fuel input module AEM and the Air Fuel module ECU master? When I order the closed loop system I got the latter (Air fuel module ECU master.)
Does the AEM allow for data logging while the ECU master does not?
https://www.hurricaneperformance.ca...t-performance-products/air-fuel-input-module/
https://www.hurricaneperformance.ca...ce-products/air-fuel-input-module-ecu-master/
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
Data logging happens with the Flasher, not the A/F module. If you activate the data logging, you can see the A/F ratio either way.
