0degC
- Jun 5, 2009
- Sudbury, Ontario
- 2023 SRX, 2017 XF 9000
do you have flasher and data logging? You may need to “enable” the auto tune. My auto tune was not working and realized can turn on/offOk I never get that code everyone talks about. With the closed loop system. Will have to look into it
0degC
- Jun 5, 2009
- Sudbury, Ontario
Tested the Hurricane tunes 240, 270, 300 and the closed loop system Saturday. Every pull, open and closed exhaust (Have the EVO Captain's choice muffler so I can have wide open at a touch of a switch). AFR's stayed around 11.7-11.9 every wide open pass.
The GAP data logging is nice and need to get an I-pad instead of using an I-phone for a dash...lol
The data logging is very nice for sure. Was testing on the weekend and reviewing logs, watching the closed loop multiplier it is often removing fuel and rock solid WOT. I can see potential of fuel savings maybe 10%. Also closed loop seems to be speed activated kicking in at 20mph.
Ontarioviperxtx
- Oct 2, 2016
- Northern Ontario
- 2018 Sidewinder xtx
16 viper xtx se SOLD
08 nytro rtx SOLD
- Kirkland Lake
Called Turbo Dynamic’s should be fixed up tomorrow!do you have flasher and data logging? You may need to “enable” the auto tune. My auto tune was not working and realized can turn on/off
justinator
- Mar 25, 2007
- Maine
- 2023 Arctic Cat Riot 9000
Are you seeing the multiplier on your phone app or are you viewing on something else? I can not see the multiplier on my iphone. I inquired with TD to see if gap would be releasing an update for the app that would give the option of seeing the multiplier but they said they didnt think so.The data logging is very nice for sure. Was testing on the weekend and reviewing logs, watching the closed loop multiplier it is often removing fuel and rock solid WOT. I can see potential of fuel savings maybe 10%. Also closed loop seems to be speed activated kicking in at 20mph.
0degC
- Jun 5, 2009
- Sudbury, Ontario
On phone.Are you seeing the multiplier on your phone app or are you viewing on something else? I can not see the multiplier on my iphone. I inquired with TD to see if gap would be releasing an update for the app that would give the option of seeing the multiplier but they said they didnt think so.
justinator
- Mar 25, 2007
- Maine
is that an android phone? I see gap had a new update for the android app in october but havent released an update to the app for iphones.On phone.
0degC
- Jun 5, 2009
- Sudbury, Ontario
Yes android. But fairly sure works on iPad so would think would work on iPhone?is that an android phone? I see gap had a new update for the android app in october but havent released an update to the app for iphones.
justinator
- Mar 25, 2007
- Maine
It definitely does not work on the iphone. Gap has not released any updates for the iphone version of their app since 11 months ago. I suspect they are working on it but I sent an email directly to gap to find out for sure. I will try it on my ipad but I believe its the same version as the app that I currently have installed on my phone. Thanks for the information, Im pretty sure I have an old android phone kicking around anyway I could use in the meantime.Yes android. But fairly sure works on iPad so would think would work on iPhone?
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Went did some testing today and I think my o2 sensor is cooked!!!
I got the code on start up and did not disappear on it's own. As soon as I rev the code disappears but when I stop and idle the code pops up...
Hammer70
GRIPNRIP
- Sep 6, 2015
- Niagara, Ontario.
Really doesn’t sound goodWent did some testing today and I think my o2 sensor is cooked!!!
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
After talking with Rob we think the 02 is ok and possibly the closed loop file is corrupt.Really doesn’t sound good
I do get readings when on the throttle. At idle the code pops up then hit throttle code clears and afr diplays
JPS
- Aug 23, 2014
- Clarks Summit, Pa
- 2018 sidewinder XTX, 2017 Viper XTX, 07 apex attack, 95 Vmax4
Damn i have been waiting for my control box since the end of October and word is they may have them in stock to ship this week. Up to this point the few closed loop systems seems that are out there are nothing but a headache. I hope i did not take a good running sled and invest even more money into it to have a headache on my hand.
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Since it's something brand new for this season I think there are a few bugs to sort outDamn i have been waiting for my control box since the end of October and word is they may have them in stock to ship this week. Up to this point the few closed loop systems seems that are out there are nothing but a headache. I hope i did not take a good running sled and invest even more money into it to have a headache on my hand.
justinator
- Mar 25, 2007
- Maine
Nothing to worry about imo, I installed mine from TD the day it was available, without unplugging afr module as I didnt know about this protocol at the time, and all is well......everything works like it should. You will be fine.Damn i have been waiting for my control box since the end of October and word is they may have them in stock to ship this week. Up to this point the few closed loop systems seems that are out there are nothing but a headache. I hope i did not take a good running sled and invest even more money into it to have a headache on my hand.
Hammer70
GRIPNRIP
- Sep 6, 2015
- Niagara, Ontario.
Justinator do you have codes stored in ecu ?Nothing to worry about imo, I installed mine from TD the day it was available, without unplugging afr module as I didnt know about this protocol at the time, and all is well......everything works like it should. You will be fine.
- 6K
