JPS
- Aug 23, 2014
- Clarks Summit, Pa
- 2018 sidewinder XTX, 2017 Viper XTX, 07 apex attack, 95 Vmax4
I already had my ECU flashed from TD, just waiting on the box and the 02 sensor with bung to weld into my exhaust. I run Max16 with TD header so they updated my ecu for the latest max 16 header flash and put on closed loop, they did not say i had to do anything special to install, just plug and play.Nothing to worry about imo, I installed mine from TD the day it was available, without unplugging afr module as I didnt know about this protocol at the time, and all is well......everything works like it should. You will be fine.
justinator
- Mar 25, 2007
- Maine
- 2023 Arctic Cat Riot 9000
Only code in ecu I see is because of the sd-24 we get at startup till the sensor is warmed up, nothing else.Justinator do you have codes stored in ecu ?
My SW with closed loop and Hurricane SS perf muffler tune bundle cruises with an AFR 13.5-14.1 : 1 on both the 240 and 270 tunes.
wide open is just over 12:1
I never tried the 300 tune
no1b4me
- Dec 31, 2016
- 2019 ZR9000 Ltd iACT
12.1 is very good at WOT with a slight safety margin,that AFR is very efficient....what is your RPM at cruising for AFR 13.5-14.1 ?My SW with closed loop and Hurricane SS perf muffler tune bundle cruises with an AFR 13.5-14.1 : 1 on both the 240 and 270 tunes.
You don't want to see anything in the 15's or higher for cruising or else you could experience a metallographic meltdown.......
Hammer70
GRIPNRIP
- Sep 6, 2015
- Niagara, Ontario.
Dave from Hurricane Hooked me up today resolved my issues a big thanks to Hurricane this was one of reasons I went with this vendor highly recommend.
Thanks Pan
scuba335
- Dec 8, 2007
- Boston, MA
- 2025 Sidewinder LTX-LE
Can someone with TD CL flashes and AFR module tell me if the AFR shows up on the dash just like Hurricane's?View attachment 158723 Update on my afr on cluster and phantom codes all fixed works perfect.
Thanks Pan
Nice to have the readout BIG.View attachment 158723 Update on my afr on cluster and phantom codes all fixed works perfect.
Thanks Pan
snowcaine
- Dec 23, 2019
- Indiana
- 20 Sidewinder
21 ZR 9000
23 SRX
Yes. AFR, boost, all the good stuff.
Ontarioviperxtx
- Oct 2, 2016
- Northern Ontario
- 2018 Sidewinder xtx
16 viper xtx se SOLD
08 nytro rtx SOLD
- Kirkland Lake
Yes it does.Can someone with TD CL flashes and AFR module tell me if the AFR shows up on the dash just like Hurricane's?
putz21
- Apr 15, 2013
- Tomahawk, WI
- '25 Sidewinder XTX LE w/EPS
'23 Sidewinder LTX LE w/EPS
So what are the steps to get AFR to show up on the Dash Flash? Go into the Gap Flash App on your phone and switch it default to display AFR vs. PSI?
scuba335
- Dec 8, 2007
- Boston, MA
After calling TD today I found out that I was running an early version of the dash flash. Once they had updated my files and I reflashed it, I finally had the large AFR reading and Boost reading.
putz21
- Apr 15, 2013
- Tomahawk, WI
Thanks for posting. I bet I have an earlier version as well as I can't seem to have the AFR reading display on my TD Dash Flash. I'll give them a call as well to look into.
zxtyler
- Dec 12, 2020
- Michigan
- 2020 SRX
When you say it’s not reading do you have 0.0 or just plain nothing?
putz21
- Apr 15, 2013
- Tomahawk, WI
I have nothing. I have PSI option to display that, but no option to see AFR. I reached out to TD to see if I need an updated version of the Dash Flash.
- 7K
