Does anyone know if a 25 uses the same exhaust header as the 28? I have a NW kit on a Nytro. The pics I've seen show the exhaust header on the 28 with a tighter radius than what my 25 has. Just thought it would leave some room between the header and coolant lines.
FLYBYU
if it has a 5 bolt i believe it's the same on the exhaust outlet side, and they have different options for inlet side most of us have t25 inlets.
uzeste
Talk to ulmer racing. They own NW now and has 28's ready to go for the NW kit good for 17 LBS.
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
It should be the same at the exhaust inlet side as well, if I remember it correctly GT2860RS is a direct replacement to the GT2560RS.
You can check with Dave at www.powerderlites.com or Ted at www.turboaddictionparts.com
FLYBYU
2860 is the replacement for the 2554, I thought.
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Norway
Seems we're both right about it, this is copied directly from Garrett
GT2860RS - 739548 - 5
* Ball bearing
* Oil & Water-cooled bearing system
* Upgrade turbocharger for GT2554R (471171-3) and GT2560R (466541-1); turbine housing flanges are outline interchangable
* T25 turbine inlet flange
* Great size for applications w/ packaging constraints
* Ideal for smaller displacement engines making up to 360 hp
* Turbine Housing option available
Happy boostin'
* Ball bearing
Happy boostin'
- 7K
