DeerHuntr said:Does an aftermarket can allow you access to the chaincase tension bolt or do you still need to remove it to gain access? Curious, might be worth it just for convenience, I usually check mine once a month or so and don't want to be replacing the gasket all time. Sounds like allot of them get tore when the can is removed.
