Hard wire connection points?
Bluebullet
Massena NY
2021 sidewinder LTX GT, 2010 Apex LTX GT
LOCATION
Maine
Looking to hard wire my safety light, where is the best and easiest location to hook up? 2021 SW LTX GT please and thank you!
You could use the accessory plug by the chain case/oil reservoir or get a power supply unit from Rockz Toyz if your light has the RCA connecter. It's a simple plug and play unit.
Thanks, I also have GPS I run in the existing RCA plug I forgot to mention. Thanks SNO
Gotcha, I direct wire my GPS on a switch so I can view it when stopped without turning the sled on. Always hated having to turn the key on just to look at GPS.
I found another wire/plug on my 2022 that i have not seen on these sleds before. It was a black and red wired small plug coming out of the wire harness just in from the collate bottle cap. Not sure if its on the 2021. I don't have a pic but if you start at the coolant bottle and work you way through the wiring harness towards the heated roll over valve.. It was a short 3-4" black and red wire connected to a quick plug that was basically coming out of a thick wiring harness.
I think that's for adding a tether....I could be wrong though.
I'm pretty sure my 18 also has that connecter.
I have a splitter on my accessory plug. You can probably do that if the light doesn't draw too much power
