grizztracks
Tech Advisor
- Feb 24, 2005
- Scio, NY
I checked my exhaust donuts a few months back when I installed a tunnel heat exchanger. The clamps where tight and the donuts seemed to be OK. I had my shocks revalved and installed pilot skis last week and was anxious to try them out this weekend but when I started the engine something didn't sound right. 15 minutes later I discovered the missing exhaust donuts. If anyone is running up on tug hill this weekend and come across three exhaust donuts they're mine. Please return them ASAP!
What a disappointment. This sled is really starting to irritate me! I'm glad I kept my Vector. At least I was able to get in 100+ miles on that today.
trailbreaker
I think i seen them out by Flat Rock. Lol
stock
How many miles on them ? Is it the bumps on Tug or just from the miles on them ? I wonder if you could do something to make them tighter, maybe grind down the spacers a bit. The Hindle is looking like a good setup. I was there Friday and didnt see any. May be I should open a Dunken Donut store on the hill might do good.
4rcefed
stock said:How many miles on them ? Is it the bumps on Tug or just from the miles on them ? I wonder if you could do something to make them tighter, maybe grind down the spacers a bit. The Hindle is looking like a good setup. I was there Friday and didnt see any. May be I should open a Dunken Donut store on the hill might do good.
I've heard of guys grinding down the clamps some to get them tighter. But, I personally think this is a bad idea. The tighter you clamp down on those brittle titanium pipes the higher of a chance there is to crack them.
I'd rather replace exhaust donuts/gaskets every few thousand miles, than buy $400 titanium exhaust pipes. But that's just me.
grizztracks
Tech Advisor
- Feb 24, 2005
- Scio, NY
A day old Dunken donut would probably last longer than these did. I remember hearing a little rattle at low speeds when I was up on Tug Hill a few weekends ago but I forgot to check it over because I got to involved in the shock revalving and pilot ski install. when I realized something was up I dropped the rear skid and looked through the exhaust manifold holes in the tunnel. I started the engine and could watch all three clamps spinning on the pipes. I have three dealers all within an hours drive and not one off them stock the parts so it's down until the end of the week.
I think I will take a mm or two off the spacers. Has anyone found aftermarket donuts that hold up better than the OEMs?
This is the most expensive sled I've owned. When my wife sees the credit card bill next month she's going to send me to debt counseling.
marsh14
I think that is covered under warranty.
fxnytroxtx
Guest
im confused what are this donuts u guys talking about and where are they located? im serious in case mine go bad thanks.
zippo
- Dec 21, 2009
i knew there was going to b alot of shyt go wrong with these sleds!!! and yami knows it as well just no that its your dealer that gets the warrenty claim pushed through
so if your dealer tells you yami wont cover it you have to ask your self
cuz every issue is different
but something like exhaust donuts thats obviouse thats a warrenty item!!
im just glad i have lived at a time where as i get to ride such a bad edit for foul language
go to a vintage sled show and see what we used to ride youll be glad what your on now
grizztracks
Tech Advisor
- Feb 24, 2005
- Scio, NY
I don't have the extended warranty and I really don't think Yamaha is going to replace them on a 2008. It's going to cost under $50 to replace them and it'll take about an hour so it's not a big deal but with all the money I've dump into it compared to other sleds I've owned I'm starting to regret buying it.
I'll be back on tug hill next week. I'm hoping those new skis and shocks will make my forget about all this. We'll see!
craigwsrx
- Feb 19, 2007
- Fenton Mi.
- 2017 Sidewinder 27,000 miles
2009 Nytro xtx 31,000 miles
2006 Attak 26,500 miles
2003 RX1 13,500 miles
2000 Mountain Max 14,000 miles
1998 SRX Mountain 17,000 miles
1995 V Max 600
1979 SRX 440
1975 GPX 338
1973 GP 338
My exhaust donuts were completly gone at 4000 miles.
2008 Nytro RTX
If you were running stock skis,Expect to be like WOW . it was the best 450 dollars I spent on that sled.
mach9
This is the biggest reason why I'm getting the stock junk off.
I'm going with the Hindle option.
Cheers
Cheers
doo_man
Just put turbos on three FX Nytros, 2 - 08's with 3000k on em' donuts were perfect still. And the other was 09 and obviously perfect.....
If not lined up right, and clamps not tightened properly you could have issues....
enticeraised
doo_man said:Just put turbos on three FX Nytros, 2 - 08's with 3000k on em' donuts were perfect still. And the other was 09 and obviously perfect.....
Ok doo man. Are you installing these turbos yourself? Total cost?
SledFreak
- Feb 7, 2005
- Ontario. Canada
grizztracks said:I checked my exhaust donuts a few months back when I installed a tunnel heat exchanger. The clamps where tight and the donuts seemed to be OK. I had my shocks revalved and installed pilot skis last week and was anxious to try them out this weekend but when I started the engine something didn't sound right. 15 minutes later I discovered the missing exhaust donuts. If anyone is running up on tug hill this weekend and come across three exhaust donuts they're mine. Please return them ASAP!
You have to tap the clamps when you are tightening them, to make sure they are not hung up on anything.......... This worked for me....
