Helix Shims
kylechargerrt
Age
35
Scotland Ontario
Canada
2017 YAMAHA SIDEWINDER LTX-LE
1998 MACH-Z
Whatv size washers is everyone running for the helix shim. Was planning on doing mine. There was some pictures but I can't seem to find them. I know 1/16" thick. Also any pictures would be great.
Sent from my SM-G920W8 using Tapatalk
when you shim it out, does it not technically give you a little more overdrive?
Are you shimming the whole helix out or shimming the points to make all 3 roller contact or both?
Shimming whole helix out to prevent coil binding.
I also remember seeing pics, but can't find them now.
Here are some pics Terry (NOS-PRO) sent me last year when I did the helix shims on my viper.
How much thread is left showing on the stud once the shims are in?
Just barely squeak threw... put a drop of blue loctite on her to be safe. Need some shims to get the belt up anyone know what size OD/ID they are gonna raid the bins at work.
My plan tomorrow is to get the machinist to make shims not washers. So there's full coverage. Also make longer studs
Just use nord lock washers with standard nuts. Fit great with shims and lock better too.
