Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
Did you make room? Lol. I'm just asking. You know everyone is afraid to go beyond 1.5" without damaging louvers. Me, I just follow the forum. I'll go out there tomorrow and see for myself. No b.s.Lots of room
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
I run same length stud last year , no issues down the centre.Ya know....you could be the only guy in the country that's ran 1.575s up the middle. And close to center. Without any issues.
You might want to take a peek. I'm just saying.
Doc Harley
- Oct 17, 2016
- Here & there
I believe it. I know there is genuine concern with stud length & louvers. But I honestly don't know first hand, At what length things get tricky. Lol.
Add: kinda funny cause i thought factory offered a 1.6 cobra on certain models?
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
There's a good 1" between tip of stud and the louvers.
Shagnos
- Jan 23, 2007
- Slowville mi
- Sidewinder
geez150
No, they have the same penetration because it shows them with two different lug heights. 1.375 and 1.5 respectively.View attachment 133447 That’s strange Woody’s list the exact same penetration for the .450 vs the .575. Is it the taller nuts on the .575 which give less penetration? So just go with the .450 since there is nothing to gain?
Conedodger
- Mar 2, 2017
- Tulsa
- shopping, blew up my 07 MachZ1000
Don't be fooled checking static room. At speed the track wants to be a perfect circle and therefore its ballooned out between turning points in the tunnel. One guy has no problem cause he weighs 140, runs groomed railroad beds never gets near full compression and runs a tighter track.There's a good 1" between tip of stud and the louvers.
Next guy at 250, rougher trails, more aggressive rider uses all his travel and a touch looser track and contact might be often and destructive.
Weight will also be a factor in how your pics penetrate.
Shagnos
- Jan 23, 2007
- Slowville mi
- Sidewinder
Duh.....lol. Must be early in the morning.No, they have the same penetration because it shows them with two different lug heights. 1.375 and 1.5 respectively.
DMCTurbo
- Nov 12, 2005
I'm not worried, I run my track tight, a lot of guys have ran longer studs with no issues. Thanks for your concern though.Don't be fooled checking static room. At speed the track wants to be a perfect circle and therefore its ballooned out between turning points in the tunnel. One guy has no problem cause he weighs 140, runs groomed railroad beds never gets near full compression and runs a tighter track.
