Richard Hodgins
- Mar 5, 2019
- Ottawa ontario
- Yamaha powered CAT
I would also look at the 137 1.75 inch track if I were you. It hooks up much better than the 1.6 and a lot more durable! I am amazed at how well it works on groomed trails.
Personally, if you want a good ride, I would avoid the 141 uncouple skid. Yes its lighter and more fun off trail, but it still will never handle as well as a 137.
I had 3 different 141 sleds and tried everything:
-Hygear linkage kit, both with a revised spring and multiple shock setups.
-Changed everything to 2018 spec with QS3 front and rear in the skid.
It handled ok to the point that I was happy with it, but if you got on a 137 back to back, no comparison. The 137 with QS3 is the best for rough trails or trail riding in general.
The new 146 intrigues me. Although its in-coupled, it still has springs as opposed to coilover shock. Maybe that's the ticket to get it ride nicer?
So I would look at a 146 1,6 cobra, or a 137 1.75 back country style skid/track.
Wingwong
- Mar 20, 2018
With regards to StudBoy ProLite backers, have you considered using doubles? See pics. More rigid and lighter than aluminum setup. For 192 studs (1.630") Stud Boy Lake Racers and StudBoy double ProLite backers, it's was almost exactly 2 lbs lighter for same number of studs. The way you keep them from stripping is to tap them first. I got this tip directly from StudBoy. Tap them (in my case w Stud Boy studs it was 1/4-28 threads) and then use Professional Super Glue when screwing them in. NO issues with loosening or unscrewing, etc. Locked so good you'll have to heat them to get them out!
I agree, IF you use PROLITE backers go with the double backers!!
But, in my opinion, buying something and having to use glue for it to work, well, that’s not a product I will use. Looks great though!
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
I've run the double ProLites on my winder for 3500 miles already and put well over 10,000 miles on them on my old turbo 1200's as well. Tap them just over half way thru and use Woody's Megabites and have never had even one failure with the backers. I love those things and will continue to use them for lighter weight and better traction. I use the plus size in the center band and std size on the outside band, and prefer to use black as not to draw attention to the studs in the track. I would never use the single ProLites myself. I prefer to use the Fast-trac SP single backers for my singles, have never had a failure with them either. Have never used any type of glue either.
Turboflash
- Mar 18, 2019
- Southern MN
The super glue is only for insurance but not required. Super glue makes it "permanent" and often it takes heat to be able to remove a stud.
ktmhk53
Suspended
- Jul 4, 2006
Drumroll.........
And the winner is...........
The 2020 Yamaha Sidewinder X-TX LE
I bought it today!
After speaking with the Camso reps, they confirmed this sled comes stock with their 2 ply track, which is better for high HP applications. They also said most drag sleds are continuing to use longer and longer track lengths each year, and this year they're GENERALLY around 159". They believe a 137" would be ridiculous to put on a trail sled with 400+ hp, and recommended the 146" to help get the power to the snow.
Thanks for all your suggestions!
I bought it today!
I think you've made the right choice. I think Yamaha was right to make the XTX a 146. Seemed a bit pointless to have a 137 and 141.Drumroll.........
I bought it today!
After speaking with the Camso reps, they confirmed this sled comes stock with their 2 ply track, which is better for high HP applications. They also said most drag sleds are continuing to use longer and longer track lengths each year, and this year they're GENERALLY around 159". The believe a 137" would be ridiculous to put on a trail sled with 400+ hp, and recommended the 146".
Thanks for all your suggestions!![]()
Looking forward to reviews of this tweaked rear suspension come winter.
ktmhk53
Suspended
- Jul 4, 2006
I have high hopes for it as well. It'll start off with new Zbroz Exits or Elka shocks so my review will be a bit biased
actionjack
- Apr 9, 2005
- Westminster, Maryland
- www.inspectorjack.com
- 2017 SideWinder LTX-LE
is the XTX 146 the same skid as the Riot? Might have to pony up.
mikextx
- Feb 19, 2017
- holland MI
- 2017 apex xtx
- Holland MI
Prices would matter. Warranty doesn't with all those mods. A Viper, or Doo 1200 would work good for less money since your buying everything anyway.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
I assume so yes....is the XTX 146 the same skid as the Riot? Might have to pony up.
number1kyster
- Dec 10, 2004
- Vermont
- 2018 SW RTX SE
If I were ordering a 2020, I would have ordered the same machine. I think that sled will be a lot of fun!
- 6K
- 6K
