Boston RX1
I just installed my Yamaha HID's 2 weeks ago. The lows are too low and I outdrive the lights, the highs are into the trees! Do you guys find this as well? I went to adjust, but I can either go up with both or down with both, but not separately. Any ideas?
Sledtime9
I adjusted my lights so that the high beam is were the low beam used to be. I ride on high beam all of the time. I switch to low beam only if i see a sled coming the other way or I am riding next to the road.
Boston RX1
You are seeing the same thing. I wonder why this was not talked about already?
take the metal shields off the bulbs, it helps dispurse the light better so there is less definition where the beam shines and doesnt. I have 2 sets and one is with and one is without. I like without better.
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
it's not specific to HID's. It's a problem with the reflectors in the lens of the sled. Had same problem with the halogens and it persisted with the HID's. I might take one bulb mechanism apart to see if the amount that the bulb moves can be adjusted.
Boston RX1
Thank you. I will try that.
BADSLED
- May 13, 2004
- Syracuse, NY
- 2012 Nytro MC Xpress 270
2011 Apex SE
2021 Sidewinder LTX SE - SOLD
stopdropanroll
ldb said:take the metal shields off the bulbs, it helps dispurse the light better so there is less definition where the beam shines and doesnt. I have 2 sets and one is with and one is without. I like without better.
DING, X2
Boston RX1
You guys are the best. I will make this adjustment this weekend and let you know.
Mooseman
- Nov 3, 2009
- Greely, Ontario
- Greely, ON Canada
stopdropanroll said:ldb said:take the metal shields off the bulbs, it helps dispurse the light better so there is less definition where the beam shines and doesnt. I have 2 sets and one is with and one is without. I like without better.
DING, X2
Won't that cause blinding for oncoming sleds? The HID are already bright as-is. By letting undefined light straight out will make it worse.
Zakre
Mooseman said:stopdropanroll said:ldb said:take the metal shields off the bulbs, it helps dispurse the light better so there is less definition where the beam shines and doesnt. I have 2 sets and one is with and one is without. I like without better.
DING, X2
This is very true, the HID's in the wrong housing are a total pain in the a$$ to look at, even worse when you take the deflectors out! I don't like looking at the sleds at night cause you cant see anything coming the other way!
SSX600
- Feb 13, 2010
- Richland Center WI
- 2010 Nytro XTX, 1997 Mtn Max 600, 1998 SSX600, 1975 SM292F, 1987 Inviter
I took my metal deflectors out when I installed the light and I still had a issue with the light adjustment also. The High beams are too high and the low beam is ok. I adjusted them down a little but haven't ridden at night since then. I will let you all know if its better. Next I was thinking of trying one bulb with the shield and on without. Has anybody done this?
Crewchief47
- Jan 16, 2006
- McGregor, ON Canada
- 2008 Nytro MTX 45th
The FX Nytro is reportedly bad on the hi/lo split compared to other Yamaha's. I saved this link a couple years ago but haven't tried it and I don't know how it would work with the HID's.
http://www.ty4stroke.com/viewtopic.php? ... sc&start=0
alsops
- Feb 17, 2009
- Headingley, Manitoba, Canada
- liverpool.com
- 2009 Nytro XTX
2021 Sidewinder XTX LE
HID
I agree
not impressed with HB
LB is better than stock
Actually the position of the LB/HB switch on the Nytro I find awkward..not sure if other think so?
I agree
bottlerocket
Has anybody tried spacing the bulbs with the washer trick on the nytro? I know it works on the apex.
