snowcaine
- Dec 23, 2019
- Indiana
- 20 Sidewinder
21 ZR 9000
23 SRX
The rotor on my dad's '20 LTX GT is hot hot with barely no brake usage. Is the caliper hanging up? Is this common? Are there any quick tests I can perform to eliminate causes?
Confused
- Oct 12, 2008
- Mound, MN
- '25 Sidewinder SRX #723
'24 MXZ 850 Turbo R Comp
'23 MXZ Blizzard 850 ETEC
'24 MXZ Neo+ 600
'88 SnoScoot
1976 SRX 440 #554
Check out the post on the BOP Shaft Saver that talks about the rotor wobbling. Maybe that is the issues you are having.
swampcat
- Mar 17, 2014
- N. E. Wi.
- 2020 S W LTX-GT
Old speed run trick. Go to the hardware store and find the spring box. Get a spring that fits over the retainer clip pin that has enough tension to push the pads OFF of the rotor. The spring goes between the 2 pads on the clip. Sled has enough drag already, dont need dragy brake pads. If you have a safe enough area, pull your pads out and go for a casual little cruise, DO NOT TOUCH the BRAKE LEVER. Check the rotor,see if its hot. If not, you know your pads are dragging Attempt at your OWN RISK.
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Run it on a stand without the pads in it. See if it wobbles> checking that the bearing is seated correctly on the shaft. I have a new 21 that came from the same factory , different stickers with a worn down drive shaft. Sled had 189 miles. I never touched a thing in the sled. Loaded onto trailer took to Michigan over Christmas break ride 189 miles and the shaft is worn to sh&(. If you have no wobble then I’m guessing the caliper is hanging
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
Did anyone remove the caliper and brake pucks for bearing regrease?
Reason I ask?
I did that a couple of years ago, had to remove the pads to get the caliper off the shaft to check my bearing.
When reassembled I noticed right away that my brakes were holding my sled back once off the throttle. Rotor was hot and pucks smelled.
I had mixed my pads up was my thought, so I simply bled the brake once and refilled the brake reservoir.
Problem solved.
- 8K
