ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
They all float(once rolling)stock....many of us have REMOVED this fully.How do you set your secondary so it floats yet be able to adjust your belt deflection on these 18 sidewinders?
Dan
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
Post 153 I mentioned how to do it.
Jacob Hinrichs
- Jan 14, 2019
- Bonners ferry , idaho
- 18 sidewinder mtx
How do I look up posts? I cant find a # on the thread we are in.Post 153 I mentioned how to do it.
alpineviper
- Aug 24, 2014
- Alpine Turbo Viper
do the old style cat shims move when the clutch opens?? seems like they might bind? i could be wrong. this seems like a great idea for mountain riding.
Pretty damn easy when you look at the lower right corner of the post and you see a number right next to the like link.
Jacob Hinrichs
- Jan 14, 2019
- 18 sidewinder mtx
I've been on alot of forums, but I cannot see the post # anywhere on this . There is nothing just like, and reply, no #
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Turn your phone sideways
Jacob Hinrichs
- Jan 14, 2019
- 18 sidewinder mtx
I'm on my phone does that matter?
Doowithblue
- Mar 17, 2016
- Waterloo ON
- 07 Mach z x (sold)
18- RTX LE
Jacob Hinrichs
- Jan 14, 2019
- 18 sidewinder mtx
Lol I'm retarded
As noted when you turn your phone sideways the post numbers show.
Jacob Hinrichs
- Jan 14, 2019
- 18 sidewinder mtx
So right now stock my secondary sitting still, not running I have a dog leg towards the motor. With the stock bolt and washer it will not float out away from the motor at all . But it will float in and out( to where the washer is stock) when engaged. So you think it would be a better idea to float my secondary where it is able to float over to "center" then when it is first engaged then it will allow it to float over to where it needs to be 1/1 ? Wouldn't the same thing be achieved by just shimming out the secondary shaft since it will float in anyway?
KnappAttack
- Feb 19, 2004
- Welch MN
Set it up with the Hurricane bar. There will then be a dogleg outward. You can them use shims inside the driven to set deflection and use a washer the size of the hub to let it float outward a couple mm.
Dan, show him how. Sounds like he need pictures or videos and has no idea on the principle of how these clutches and belts work or line up.
ClutchMaster, someone help me out. I gotta tap out.
alpineviper
- Aug 24, 2014
Arrogance at its finest
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- 2015 Viper 270 hurricane,
- Wisconsin
Dude that is just plain rude!
Mike has been trying to help you guys understand the concept. He’s not getting anything for helping you, nothing!
Now you come out with this attitude, if you disagree then why are you so full of questions?
Plenty of info on here as to what Mikes talking about, just do a search and you’ll find it! instead your asking him to rehash stuff that’s all over this very site.
Silver platter.........
https://ty4stroke.com/threads/does-the-sidewinder-secondary-float.149944/
As for the dog leg in your belt at idle, well the belt isn’t even tight so yea it’s gonna look way off. Take the belt guard off put it on a stand and engage the clutches. You will see that when the belt is tight it’s much straighter.
Here I’ll dumb it down for ya..... look at your sheaves coloring, if the inside sheave of the driven is darker than the outside sheave then your offset is too high. You want them both the same finish and color, your close enough.
Still having issues, then look at you clutch setup it’s probably junk.
Have a little respect, 2win
- 11K
