How many have bought the Hurricane alignment tool ,and used it .?
Do you have a accurate way to check alignment?
57.5-58 mm is where you want it.. I do have the Hurricane tool. But I usually just measure with a bar
I do know my 2022 primary clutch came off way to easily while taking it off.
I was at 57.9 on my 2022 when I brought it home with no washers behind secondary... I removed the clutches and had some "WORK" done on them, Balance, etc.. So I installed them the other day and I was 58.5 mm. Like I said the primary was not torqued on nearly enough from factory.. I removed .6 mm form my stub and now sit at 57.9 mm.
Otherwise remove any WASHERS form behind the secondary and run it with the Cir. clip . You will be very close
I believe there was a way described to do it with a straight edge.
If I can find that, I could use something I already have.
Thanks for the info. I will get torque before measuring.
