34pontiac
I had a machinist do it Charged me 5 dollars.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Most guys have to remove approx 3mm from back of sec hub....I had my machinist remove this and had him make custom shims, 1.5, 2mm, and I have stock 1mm. Then set where you want.We’re and what size shims are available mine is out 1.7 mm. Also how is everyone removing this material fro the back of there secondary.
Thanks Pan
Read my post here: https://ty4stroke.com/threads/my-rtx-le-50th-build-thread-rockerdan.149801/page-18#post-1403350
Dan
Remove spring, Open fully.....
Approx 3.8mm hub showing stock....
You want HUB flush on backside of sec after machining....when fully opened without spring installed....like this.
Hammer70
GRIPNRIP
- Sep 6, 2015
- Niagara, Ontario.
I’m going to look at clutch’s without spring.when I pulled mine apart Dan I had no shims from stock I just ordered 1mm and 2mm shims gotta get a hold of my buddy he’s a machinist. I keep you posted as I have to do 2 other sidewindersMost guys have to remove approx 3mm from back of sec hub....I had my machinist remove this and had him make custom shims, 1.5, 2mm, and I have stock 1mm. Then set where you want.
Dan
Thanks For the info Dan Also Yamamarc is a Hurricane rep for northern Ontario now
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
Awesome...Keep us posted on where yours lands....Some dont need as much, but will see. I have not even used my new hurricane tool yet been too darn busy. I know I set mine around 58mm or so, which is a net move inward of 2.5mm after shim.I’m going to look at clutch’s without spring.when I pulled mine apart Dan I had no shims from stock I just ordered 1mm and 2mm shims gotta get a hold of my buddy he’s a machinist. I keep you posted as I have to do 2 other sidewinders
Dan
SPM
- Nov 18, 2018
- so. mn
- 2018 Sidewinder L-TX LE
Has anyone seen different readings when flipping the bar? I get about. 050 one way and .030 after flip. I checked bar for straight on a certified granite surface where I work, all good.^^^Not all sidewinders were delivered with a shim behind the secondary. It's a common part and should be in stock or you can easily find it online. part #8JP-RA448-00-00 WASHER -1mm.
I like using the gauge with wide part down to clutch, seems easier to see and measure and don't see a difference if I flip the gauge. I've flipped the bar many times and get different readings. Not sure how much to machine off. What am I missing??
PowderFalcon
Pinnin' it!
I had to machine 2.9mm off of mine according to hurricane bar.
kimcoop1324
Has anyone installed the hurricane stub shaft and then used the tool? Well I had my clutches spot on with tool prior to installing new shaft and now I need to add shims behind machined secondary. Is this new shaft made to correct rattle and offset?
Yes, built in
kimcoop1324
So now I will need to add shims behind secondary and also to plug since I machined both?
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
Yes Dave knew about the 3mm from way back. So he made the stub shaft the proper length to include the proper offset. No need to machine 3mm of secondary hub then. Win Win! So Dave's stubs shaft solves two things! Hurricane always bringing the innovation.
If you already machined secondary, you will need to add back in shims to get aligned w/his bar. Likely 3mm.
Dan
SPM
- Nov 18, 2018
- so. mn
I'll try this again...has anyone noticed different readings when flipping the clutch tool? How's the best way to measure, feeler blades? I read a lot of precise amounts (usually about 3mm) but I'm not seeing that much on my sled, about 1mm depending on which way the tool is installed. The tool is straight and I've watched the videos. I just want to make sure I'm not missing something before machining it. Thanks for any input.Has anyone seen different readings when flipping the bar? I get about. 050 one way and .030 after flip. I checked bar for straight on a certified granite surface where I work, all good.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
https://ty4stroke.com/threads/clutch-offset-question.154535/
Beerman
- Nov 22, 2004
- Plymouth, MN
- www.loyalshepherd.com
- Sidewinder LTX-SE
- YOUTUBE
- arttyszka
Why not call Dave and ask? Seems odd a straight tool/piece of metal could get different readings depending on orientation, but I know others have found the same.I'll try this again...has anyone noticed different readings when flipping the clutch tool? How's the best way to measure, feeler blades? I read a lot of precise amounts (usually about 3mm) but I'm not seeing that much on my sled, about 1mm depending on which way the tool is installed. The tool is straight and I've watched the videos. I just want to make sure I'm not missing something before machining it. Thanks for any input.
SPM
- Nov 18, 2018
- so. mn
Thanks for the info 1nc 2000.
SPM
- Nov 18, 2018
- so. mn
I agree, that's why I wanted to ask around here. I would give Dave a call but my work hours makes that difficult. Thanks.Why not call Dave and ask? Seems odd a straight tool/piece of metal could get different readings depending on orientation, but I know others have found the same.
- 11K
