Studroes144
- Oct 30, 2013
Jeez newtron I sure hope that's not the case! Unfortunately i do have snow but can't ride now because of this!
newtron
- Jan 2, 2010
- 2020 900 ACE Turbo, 2019 SRX, 2018 850 X
I'm not sure what happened but what a sh*$ show. I could post pictures of what it looked like but it would make you cry. They had the engine out of it on the work bench
Studroes144
- Oct 30, 2013
How did it go from starter gears breaking to throwing the timing off?
Alsim
- Oct 6, 2014
- LTX SE 2018
Now, when I start the engine, I turn the key and I don't release it until the engine fire up and run. Just to avoid the kick back...
newtron
- Jan 2, 2010
ya I just keep cranking till it starts. Not sure about the timing, but Yamaha came good for everything. Starter, ring gear, timing chain etc etc...
happens again I would have to try something else....season too short for that
Studroes144
- Oct 30, 2013
So what all happened to the turbo stuff? Did you switch it all over to the new sled?
newtron
- Jan 2, 2010
yep. They first though turbo was problem but too many stock sleds having same problem
newtron
- Jan 2, 2010
dealer though that
Studroes144
- Oct 30, 2013
Gotcha, well I hope it never comes to that. We'll keep posted on the outcome
newtron
- Jan 2, 2010
ya keep us posted. They need to drain the oil pan. The chunks will be in there....no where else to go
Studroes144
- Oct 30, 2013
So engine definitely needs to be pulled for that?
tator
my uncle did his nytro himself. drained the oil and slid a magnet arround the pan with a wire on it. never removed the motor (out of warranty) no issues after that . but if it were me i would have the dealer go through it all. i have warranty though.
newtron
- Jan 2, 2010
I guess. They found chunks on the magneto side and some in the oil pan
Alsim
- Oct 6, 2014
- LTX SE 2018
I'm not sure if the 2015 have the same issue? I hope it will be fix!
