1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Found some gaps above the factory frog skin vents and letting snow in on my clutches when following close behind another sled.
Going to put some foam with sticky back in those areas to close the gaps between the hood and vents.
I believe the secondary clutch blows air up and out the vent ahead of steering stem.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
Showing some wear from hood on intercooler.
Anyone have a fix for this?
Putting soft velcro in that area? Or cutting inside of hood so no rubbing occurs?
This intercooler works great trail riding. The temps recover so quick running corner to corner thru the UP trails.
earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
Don't have that intercooler although the inner me has pulled the trigger numerous times, the outer me keeps talking myself out of it.
Velcro might wear out quickly although it will work fine for awhile. You can get both Teflon and UHMW in tape form. It will create a super slippery surface between the plastics and the intercooler without adding much thickness. If you put it on both the intercooler and the plastics it should just stop any wear. You can get it from wood working shops, amazon, etc.. they call it speed glide, anti-friction tape, etc.. Not sure how well the adhesives will work in super cold weather although the 3M version is rated well.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
My best bet is to trim back the hood some so it won't rub in that area. The intercooler is bolted to the engine block so its a set distance with about 1/8" clearance on steering shaft.
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
Do you still have the factory air ducting on the hood ?
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
Which is better? With or without the ducting?Do you still have the factory air ducting on the hood ?
Edit, hood won't fit on with ducting installed.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
My next question about the ducting would be how does it affect air flow thru cooler.
With the factory air ducting removed the intake in the hood became a vent to push air out from under the hood.
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
I was just trying to help your clearance issues. Personally mines removed as well . Also drill holes in the plastic just above and behind the stock inter cooler. The plastic right in front of the relay and fuse holder, and no never had any issues but I don’t do any off trail riding
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
Ill take any help with the clearance issue.
The picture in post 32 shows that area opened up with snow screens installed.
The majority of my riding is on trail and occasionally off trail.
Any issues with snowdust hitting cooler and then getting water on clutches creating belt slip?
If I come right up behind another sled and wait for a good spot to pass i get some belt slip at that time from the snow dust.
Thinking about sealing up the front of hood with foam above the factory vents and center section where the hood comes together.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
Thinking about installing thick foam or a p seal across this area where the purple line is.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
I wasn't going to post this, but it's a sleeper sled....
Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
Icy cold, looks good!
REDLINE 1
- Sep 20, 2019
- ROUND LAKE IL
- 2018 TCAT
So is that a shroud u fabbed to cover the cooler and the fan forces air thru?
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
Sure is!
- 22K
