DooZ
- Feb 26, 2007
- Minocqua, WI
- ZR9000RR
Doo 1200
You've got some lights on that bad boy too...
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
You've got some lights on that bad boy too...![]()
Couple of spot lights wired into the hi beam switch.
Cannot outrun those at night.
Cheap Tractor supply lights.
They will light up a quarter mile!
I have those lights on my Kubota tractor for nite snow plowing/blowing. They work good.
hpmaniac
- Feb 21, 2025
- Washington
- 2025 mtx sidewinder
2024 9r turbo
2025 summit xpert 165 turbo r
wow this is the intercooler set up i need, How much difference did you see when you installed the secondary cooler? i am fighting high intake temps on my 300 header tune. I was going to install a fan but this looks trick. What did you use for material for the shroud?
- 22K
