Darko
slymax said:I can't try mine this weekend as I sent my fuel controller for re-mapping.
Why the did you send your fuel controller for re-mapping?
I thought it was good for 15lbs. Do we need more?
slymax
Sounds like the mapping that came is a little rich. They said to send them back for the new mapping update. Still good for the same boost as before, just a little leaner and better running. Hey, I got enough of my own crap to do(handwarmers etc) that's why those guys make the big bucks, LOL. They have a better fuel map, I'll take it.
canadianhunter
The spray foam will help a bit IF you do it right.
When you spray to much foam in a tight place it cannot expand and remains a glue like consistancy[I have seen it stay like this for a couple of months] that drawes heat away. Spray in alittle at a time so it can expand and it will insulate and help.
Snowest
I have noticed when riding you go to check the hand warmer setting and it is down two bars on the gragh, turn it up to full bars, check the setting a minute later and it is two bars from the top again.
bigrock33
- Apr 15, 2005
Snowest - are you sure that you are looking at the handwarmer graph or has it gone back to the fuel graph?
Snowest
Know what you are saying but, i'm looking at it right. After a few seconds it defaults back to the fuel gauge then if you go and push hand or thumb warmer button it is not at the top.
