Richard Hodgins
- Mar 5, 2019
- Ottawa ontario
- Yamaha powered CAT
Has anyone had this happen before? It’s just one mounting bracket but am wondering if the case should be changed or just run it.
I am sure these are backordered!
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
A better pic would be helpful. Maybe a closer pic and one further out ? I think it kind of depends where the crack is? Obviously you probably should fix this but
Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
Why wouldn't you just get it welded? Make me feel better.
Richard Hodgins
- Mar 5, 2019
- Ottawa ontario
It’s one mounting tab to tunnnel , the others are all fine. No leaks from case and everything else seems fine. Will try and get a better pic. There are other mounting tabs/ears close to it which are fine.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Any idea what its from? Did you go off trail and hit something? If you run it just realize the harder you beat on it the more flex and stress on the tunnel and mounting's. Not saying you beat your sleds.. Maybe just go a little easier on it in the rough stuff? Stay on trail.. Not sure about welding magnesium?It’s one mounting tab to tunnnel , the others are all fine. No leaks from case and everything else seems fine. Will try and get a better pic. There are other mounting tabs/ears close to it which are fine.
Richard Hodgins
- Mar 5, 2019
- Ottawa ontario
Its a friend's new sled that he picked up from a dealer, so no history on it. 4000 miles. I would assume this could have been from hitting something hard (although I would imagine more would be cracked?) or overtighten from factory. I see most people were getting this back case replaced under warranty with similar cracks but this is a 2018 so no warranty. Am wondering how much stress is actually on it, if just JBwelding will be sufficient and run it.Any idea what its from? Did you go off trail and hit something? If you run it just realize the harder you beat on it the more flex and stress on the tunnel and mounting's. Not saying you beat your sleds.. Maybe just go a little easier on it in the rough stuff? Stay on trail.. Not sure about welding magnesium?
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
10 4. I would replace it if possible.. JB probably wont do much in that spot, worth a try. Keep a eye on it.. If the sled is going to be run hard in big stuff it could put more stress on it or the remaining bolts that are holdingIts a friend's new sled that he picked up from a dealer, so no history on it. 4000 miles. I would assume this could have been from hitting something hard (although I would imagine more would be cracked?) or overtighten from factory. I see most people were getting this back case replaced under warranty with similar cracks but this is a 2018 so no warranty. Am wondering how much stress is actually on it, if just JBwelding will be sufficient and run it.
sxr70001
- Dec 4, 2010
- Michigan
- Sidewinder LTX SE
SR Viper RTX SE
Order a new one and jb weld it for this season. Hope for the best.
Fords4life
- Dec 7, 2021
- South Dakota
If it were me, i pull the bolt out clean the area real good, fire up my mig welder with aluminun spoolgun and weld it in chassis, then run a tap or thread chaser thru hole and retorque bolt.
stgdz
- Mar 27, 2021
- Buffalo MN
Can be brought to a welder and fixed.
REDLINE 1
I may be wrong but I thought these cases were magnesium. Not sure it can be welded
stgdz
- Mar 27, 2021
- Buffalo MN
You can weld magnesium but I would first ask the welder if they have ever done aluminum and then ask if they can do magnesiumI may be wrong but I thought these cases were magnesium. Not sure it can be welded
REDLINE 1
Ya I think it’s pretty specialized process. I know casting it can be dangerous magnesium fires can get out of control pretty easyYou can weld magnesium but I would first ask the welder if they have ever done aluminum and then ask if they can do magnesium
Richard Hodgins
- Mar 5, 2019
- Ottawa ontario
Seems I will just run it as is. Posted on FB groups, and some people have 20,000 kms with a cracked ear. I believe this may have even happened at factory from overtightening. Will monitor it this season and see how it goes. Too bad the case is magnesium, not worth risk of welding.
stgdz
- Mar 27, 2021
- Buffalo MN
The ears on the case and covers crack super easy. The proper way to do it and a pain in the #*$&@ is to start at a 1/4 final torque value and go all the way around in a star pattern, then 1/2, then 3/4, and then final torque.
The cover can get misaligned easily.
