installing carrillo rods
wantboost
upstate ny
thinking i should update my rods this year since i'm turning up the boost.are the carrillo rods just plug n play on these engines meaning do they match up to the factory size journals or do i have to measure the new and poss change rod bearing size?
You have to plastigage for each rod bearing.
It's true that you should plastic guage ALL gearings to check your oil clearance but we have found that the big end of the rods are pretty uniform to the oe size.We keep Carrillo instock,always
