DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
Ok thanksYou attach the tester to the hose/tube exiting the turbo compressor leading into the intercooler.
DMCTurbo
- Nov 12, 2005
Will pm you shortly. Thanks.If you want to borrow mine let me know.. I'll be in sudbury over the weekend sometime
Sledroll
- Dec 19, 2005
- Muskoka , Ontario
- 2022 SRX LE
2017 SW LTX LE
I would possibly trailer to Sudbury this weekend , to get mine tested ,if possible, even though it is so darn cold up there.Will pm you shortly. Thanks.
DMCTurbo
- Nov 12, 2005
It's looking like it'll be next weekend.I would possibly trailer to Sudbury this weekend , to get mine tested ,if possible, even though it is so darn cold up there.
Sledroll
- Dec 19, 2005
- Muskoka , Ontario
- 2022 SRX LE
2017 SW LTX LE
Please keep me informed as your plans unfold .It's looking like it'll be next weekend.
Would love to hook up .
Test the boost , watch/do some speed runs , go for a ride .
What ever works .
I am only pulling 8500 ish with the 825 XS belt , and getting lights flashing intermittently at that rpm full out .
I will put a stock belt back on and see what that does .
I have not shaved the clamps as it appears to be beyond my capabilities.
Your clutching is too heavy and that is also why you are flashing DETOPlease keep me informed as your plans unfold .
What ever works .
Sledroll
- Dec 19, 2005
- Muskoka , Ontario
- 2022 SRX LE
2017 SW LTX LE
Went out today with the 8JP belt on and revs increased to 86-8700 , with no lights !Your clutching is too heavy and that is also why you are flashing DETO
Still seems a little low , and I would prefer to go back to the XS825 so appears that I need to reduce the weight .
I don't go inside clutches , so I will reach out to someone to change the weights .
DMCTurbo
- Nov 12, 2005
I will keep you in the loop. If you do come up I can dial in your clutching for you. What weights are you using? Tuned?Please keep me informed as your plans unfold .
What ever works .
Sledroll
- Dec 19, 2005
- Muskoka , Ontario
- 2022 SRX LE
2017 SW LTX LE
I can almost come up at any time as it is only a 2 hour drive in good weather.I will keep you in the loop. If you do come up I can dial in your clutching for you. What weights are you using? Tuned?
I have the 240 Hurricane , with Dalton weights . Not sure which ones but I assume they are the Hurricane recommended set up .
I have the upgraded BOV , and all other primary and secondary components are Yamaha stock .
The helix is the Yamaha upgraded two stage that Yamaha came out with for the 17's.
I previously snapped my primary spring in three pieces , and it was replaced with an unknown spring .
I have only trashed one belt ever , and that was self inflicted , by high revs for 1/2 hour straight on the lake with 2 feet of powder.
I would really love to see what my offset is .
My sled has been a great sled to drive , but is getting long in the tooth .
Hell , I'm getting long in the tooth .
Look forward to coming up .
yamahahaapex
Digging into this tonight.
yamahahaapex
Got this done tonight. Took me quite a bit of time. Had the tools I needed just really cautious and never wanted to drop anything. Didn’t remove anything at all, hoses. Had to slide coolant tank aside but in the end it’s done and will be put back together tomorrow. The write up on this thread was very helpful. A steady hand and patience is a necessity.
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
For those who want modified intake spacers, but maybe don't have to tools to grind them down. I've added already modified ones to our website for purchase.
https://shop.ulmerracing.com/Modifi...&browse=-73647&shopBy=-26776&catalogId=-11683
REDLINE 1
- Sep 20, 2019
- ROUND LAKE IL
- 2018 TCAT
I was bored so I did this mod last weekend. Took the throttle body off , much easier to get at the front spacers. Took around 3 1/2 hrs. Not too bad a job just have to dig thru a lot of crap to get down to the T body
RAMSOMAIR
My hands were beat up for 2 weeks lol
REDLINE 1
- Sep 20, 2019
- ROUND LAKE IL
- 2018 TCAT
Lol and I bet you made up several new cuss words to
